sierra changing fom auto to manual and bhp info plz
Old Apr 26, 2009 | 10:50 PM
2litretwincam's Avatar
2litretwincam
Default sierra changing fom auto to manual and bhp info plz
hi there
im changing a sierra from automatic to manual its a k reg 2litre twin cam model
also putting in a 1.6 engine as specified to racing( special rods at mendips)
is it just a straight engine and gearbox swap and pedal box?
also anyone know the factory standard power of a 2litre twin cam in injection?
thanks
Old Apr 27, 2009 | 08:33 AM
martysmartie's Avatar
martysmartie
Standard power is 123 BHP, what box are you thinking of using with the 1.6?
If you have got 1.6 CVH then it may be worth the engine conversion over the twinky as you can't tune these very well.
Martin
Old Apr 28, 2009 | 11:43 AM
2litretwincam
im hoping to use a 4speed 1.6 box ( 4 speed cos of size of the track) the engine is having a full rebuild before putting in
the 1.6 is from a ford p100 does it make a difference its not from a sierra? and yes the 1.6 is a pinto
thanks
Old Apr 28, 2009 | 06:13 PM
martysmartie
No should just be a straight swap with the 1.6 and box not sure about the final drive and diff though for the auto final drive may be diffrent on the auto.
Is it a 1.6 CVH or Pinto?
Martin
Old May 1, 2009 | 11:07 AM
I know the final drive on my d reg sierra 2L(pinto) was 3.38:1, rather than the more common 3.62:1.
cameron2
Aug 25, 2015 07:18 AM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
