Check my new blower out! :-)
Oh right cool, should shift some air then! Looks like it's got the standard rst elbow on it, does that not restrict flow from what i've heard? Do you know anyone running the same turbo/power outputs?!! Oh i'm assuming it's going on an rst lol??! 1.6?
It currently has the RST elbow and a 0.63 exhaust housing but it will be going in the westfied on the 1.CVH from my ERST so i will have to have an exhaust made for it anyway. If it goes on the Std RST manifold it need to have a spacer on the joint face of 10mm because the compressor housing catches No4 outlet. I havent heard of anyone running the same setup but im thinking it should be able to flow some serious amount of air. I would like to try a smaller exhaust housing tbh to make it spin up a lot quicker!
