Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
wiring focus mk1 headlight to facelift ones
Old Apr 26, 2009 | 08:00 PM
f6cus's Avatar
f6cus
Default wiring focus mk1 headlight to facelift ones
anyone got the diagrams for it have been told there is a wire that needs moving from the switch to the main beam stalk think the diagrams are in the focus max power book if anyone owns it
Old Apr 26, 2009 | 08:14 PM
n13los's Avatar
n13los
theres a how to on ffoc mate.
thats what i used on my old focus and my mates focus and another mates focus you get the idea
you dont need to move any wires in the switch, you do need to leave one wires long as it needs to go down to the posative on the indicator plug.
Old Apr 26, 2009 | 08:28 PM
f6cus's Avatar
f6cus
cheers mate were abouts on the web site is it mate
Old Apr 26, 2009 | 08:54 PM
n13los's Avatar
n13los
used to be in the how to section, aint been on there in a while tho. so might not be there anymore.
have used this guide also, its actually better anyway.
http://www.focusowners.com/forum/vie...p?f=90&t=38435
hope it helps mate.
Old Apr 26, 2009 | 09:02 PM
n13los's Avatar
n13los
just read that one, its not the one i used. i actually butchered some old headlamps from work to get the plugs and made conversion looms as i didn't want to cut any wires.
Old Apr 26, 2009 | 09:22 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I knew no-one would own up to having the Max Power Focus book
Old Apr 26, 2009 | 09:27 PM
RichieST's Avatar
RichieST
You do need to add a wire into the indicator stalk. I can't remember where it goes, but on the prefacelift lights, the dipped goes out when you select main beam, which on facelift lights (seperate main and dipped) you don't really want!
It doesn't go from the headlamp switch to the indicator stalk, it is just a small piece of wires bridged across 2 pins on the indicator stalk if you get what I mean.
All it does is stops the dipped beam going out when you select main.
Old Apr 26, 2009 | 09:28 PM
neilgf's Avatar
neilgf
Hopefully this one helps.
http://www.focusfanatics.com/howtos/st170_headlight/
Old Apr 26, 2009 | 09:36 PM
Daveysaff's Avatar
Daveysaff
Is there still a write up on the FFOC Rich? We've got the facelift headlight plugs off a golf or passat or something, just cant for the life of me remember where the diagrams have gone that I had saying which pin does what.
Old Apr 27, 2009 | 08:31 AM
RichieST's Avatar
RichieST
There is mate, however I stopped using ffoc when they started charging you to use every section of the forum apart from general chat!
I did do it on my old focus, however I don't remember which pins it is. I'll do some digging for you later to see if I can find out!
Old Apr 27, 2009 | 09:07 AM
Daveysaff's Avatar
Daveysaff
About the same time I did then!!
I though either you or Will would be able to help us out
Old Apr 27, 2014 | 10:40 AM
focus 4x4's Avatar
focus 4x4
Pin 9 green/blue in indicator stalk plug cut off before plug as this is not needed and extend this wire over to the main light switch . Look at the multi plug at the back and join it to the smallest Green/Red wire. It should be the 3rd one in from the left as you look at it.(solder to existing wire)
Old Apr 27, 2014 | 12:32 PM
Colin_P's Avatar
Colin_P
Fucking hell.
Five years to the day the reply above took. Nice.
Old Apr 27, 2014 | 02:05 PM
focus 4x4's Avatar
focus 4x4
Originally Posted by Colin_P
Fucking hell.
And now it's complete !
.... Didn't realise the thread had an expiry lol
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
hazbaz1984
Jul 30, 2015 05:15 PM
