ARGHH Sick!!!! (feeling better now)
Got my turbo in, all piped up, wired up, injectors in, everything!!
Start the engine, what do you know!? the oil feed hose it leaking at the 90 degree bend on the turbo side!
What could cause this? a crappy crimped connector, becuase the other connector doesn't seem to turn as much as the leajing one!... Or could it be too much pressure in the turbo (blockage? possible?) that's causing the line to pressurise so much that it started leaking?
I have no idea, gonna try turning the feed around and see if it leaks from the other connector this time ..
Thought i would have been boosting tonight but that let me right down!
aye i'll take it back tomorrow and get it redone, got a bit of excess to play with anyway!
so could it be anything wrong with the turbo that would make it leak? i wouldn't have thought so but when my mate said that the turbo might be blocked and pressuer building up i had to think about it
cheers.
cheers.
Up!!
Just a pipe prob then aye? probably not anything else like turbo.. just need to know as i need to get the car atleast running tomorrow!
thanks!
thanks!
yeah thanks! i thought so too!
just pee'd off coz all that effort i put into it at the weekend, and my bodge job works a treat, just a professional guy doing a professional jobs fecks up a simple pipe!
tut tut
i'll let yous know tomorrow of the outcome!
not yet mate, it's only a temporary(sp) install at the moment and things are a bit tight but should be fine!.. get my welder in a week so i'll be making up a new manifold within a few weeks and sort things out properly.
I'll get pics tomorrow if i'm not too busy!
got the hose sorted today, put it in and no leaks at all!
just waiting for my neighbour to get home to see if he can weld up my exhaust for me tonight!
woohoo
i'd be very intrested to see some pics etc.
any more info on what route youve gone down with regards to fueling? mapable 5th inj? TT DCU? or done it how graceland did it?
rsguy
44
Sep 29, 2015 03:29 PM
