i cant get my head round i for the rear.wouldnt you be spacing the drum out from the hub and the bit that the shoes go on to to stop the car?
it goes behind the back plate,the bit that the brake shoes attatch to.
ie. undo the 4 bolts that hold the stub axle to the beam. drill out the rivets that hold the back plate,if they are not allready broken to the rear beam.then fit this inbetween the beam and the back plate.
they are also available in a angled state.so you can add camber to your rear wheels.
