removing rear shocks from s2 ?
Old Apr 23, 2009 | 02:44 PM
ste45's Avatar
ste45
Default removing rear shocks from s2 ?
i am currently trying to fit my konis to my s2 but when i have come to undo the bolt on top of the rear shock inside the boot its just spinning the whole shock if you know what i mean ? do i need a special tool or sumat to undo them or and i doing sumat wrong ? thanks in advance
Old Apr 23, 2009 | 03:38 PM
haz87's Avatar
haz87
Have you put an allen key in the top of the shock to stop it spinning (obviously hold the allen key too,lol)
Old Apr 23, 2009 | 03:58 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
wht haz said,or undo it when its on the deck as it should put enuff pressure to undo it!u can grip the shaft of the shock also if u aint got a spanner tht fits it properly,
also be careful of the brake pipes!
Old Apr 23, 2009 | 04:05 PM
ste45's Avatar
ste45
i have tryed gripping the bottom of the shock but its the metal bar ( dnt know correct word) that goes inside the shock itself thats spinning , i tryed an allen key but carnt hold that on and put socket over it to undo if you get me , and it seems a little low into the cup to get a spanner onto it aswel ??? cheers
Old Apr 23, 2009 | 04:12 PM
dangerousbrian's Avatar
dangerousbrian
only way i could get mine off was with a windy gun..couldnt think of a better way
Old Apr 23, 2009 | 04:31 PM
orion_crazy_carl
orion=mini saff
grip the metal bar mate
Old Apr 23, 2009 | 04:40 PM
ste45's Avatar
ste45
ok will try that thanks for the help lads
Old Apr 23, 2009 | 04:44 PM
kellyalfie's Avatar
kellyalfie
allen key and a ofset 19 ring spanner
Old Apr 23, 2009 | 05:09 PM
haz87's Avatar
haz87
As above. Use a spanner and allen key, not a socket
Old Apr 23, 2009 | 05:17 PM
RSandy's Avatar
RSandy
yup, swan neck style spanner, and an allen key, job jobbed
although an impact gun doesnt half make the job a lot less hassle lol
if u need to further hold the shaft of the strut, pair of mole grips do the job nicely
Old Apr 23, 2009 | 05:41 PM
ste45's Avatar
ste45
cheers lads will have to get a offset spanner from work 2mra
Old Apr 27, 2009 | 12:47 PM
JesseT's Avatar
JesseT
Alternative way is to undo the bottom of the shock first, then pull the shock from the bottom sideways while undoing the nut. It won't spin if it's pulled to side. This is tricky alone though...
orion88
29
Feb 16, 2016 08:47 AM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
