Sapphire clocks into 3dr ........ question?????????
The multi plug in rear is different.......
anyone know which wires go where???
When my back sorts its self out i'll get in the garage and look at the wiring on the std plug and compare it to the newer style 1....
Ta
Steve
anyone know which wires go where???When my back sorts its self out i'll get in the garage and look at the wiring on the std plug and compare it to the newer style 1....
Ta
Steve
Dingy......
I'm not at work to look at a wiring diagram (it was a sunday when I posted and hoped someone may be able to help that has done it b4 to save me the hastle of trawling thru the wiring diagrams of the 2 cars)......
Spadge....
not got a std set of 3dr clocks at moment (thats what i was gonna do if I had a set)
What I could do with is a decet photo of the rear of a set of 3dr clocks
Spadge....
I need to know this aswell!
Steve if u get a wirign diagram any chance of faxin/emailin me it!
need to put my 3dr clocks in2 a mk4 escort efi though! so if u got a wring diagram for that aswell!
Lewis...
when i'm back at work (off at mo due to tearing a ligament "spl" in my back) i'll check the Cosworth manuel and tell you the colour of the 12 wires and what they correspond to, I maybe able to tell you the RST 1 as well but only via the Haynes manuel
excuses sxcuses! get back to work ya bum!
Im in no rush lol!
r the wiring diagrams in the Cosworth manual then!? cause I got me 1 of them!
r they car specific i.e. ssaff, 3dr, esc!?
Its a efi 3i that the clocks will b goin in2! so will c if i can get a haynes manual for 1 of them! unless u got 1 somewhere!?
Im in no rush lol!
I dunno about the manuels....... I hoping that it'll give diagrams for the Saff and the 3dr as the plugs on the clocks are different...... I think I may well give up and just buy a set of 3dr clocks....lol
lol
Well i am gunna get a set of 3dr clocks in2 that mk4 if it kills me!
Ryan's gunna cut me off the section of 3dr loom i need! then hopefully its just a case of workin out which wire does what! with both clcok sets there hopefully i cna do as spadge said & just trace the copper wiring round!
3dr clocks r better anyway! boost gauge!
(thats the only reason I am fittin them instead of leavin stabndrad clocks!
3dr wire colours......
1. BROWN WITH WHITE TRACE
2. BROWN
3. BROWN WITH YELLOW TRACE (2 WIRES)
4. BLUE
5. BLACK WITH GREEN TRACE
6. BLACK WITH WHITE TRACE
7. -----
8. BROWN WITH GREEN TRACE
9. BLACK WITH YELLOW TRACE
10. BLUE WITH WHITE TRACE
11. BLUE WITH BLACK TRACE
12. GREEN
13. GREY WITH GREEN TRACE
2. BROWN
4. BLUE
7. -----
12. GREEN
Saff wire colours......
1. GREY WITH GREEN TRACE
2. BROWN
3. BLUE (2 WIRES)
4. BROWN WITH YELLOW TRACE (2 WIRES)
6. BROWN WITH BLACK TRACE
7. BROWN WITH WHITE TRACE
8. GREEN
9. BLACK WITH WHITE TRACE
10. BROWN WITH GREEN TRACE (2 WIRES)
11. BLACK WITH YELLOW TRACE
12. WHITE WITH BLUE TRACE
2. BROWN
3. BLUE (2 WIRES)
8. GREEN
Tony W
Sep 9, 2015 12:08 PM
