ABS pump leak 3door
Any hints and known problems with the ABS pump on a 3door?
Had mine off to cure a leak, but still leaking a small amount but dont know where. A real pain in the a@%e, need to cure this to finish the car
any help please
gary
any help please
gary
hello mate it mite be easyer to just replace the hole unit. my mate one has a leak so im putting a bias pedal box on there( which i made as a replica of a ford motor sport one).ive also removed my working abs pump/valve block/loom/sensors and so on to put a bias pedal box on my 3dr as it opens up a hole load of adjustments from front to rear and you can change the power of the brakes by the cylinders
