quick...........
Old Dec 5, 2004 | 02:27 AM
cabrio boy's Avatar
cabrio boy
Default quick...........
question my s2 rst engine now when under load cuts the car clean out for a couple of seconds backfires then comes back on again as normall what could be making it do this????
Old Dec 5, 2004 | 03:46 AM
digita1dragon's Avatar
digita1dragon
ive a quick question for you! is this at 7000 revs?
Old Dec 5, 2004 | 04:42 AM
mattbibs's Avatar
mattbibs
spark plugs???
Old Dec 5, 2004 | 05:31 AM
james_birch's Avatar
james_birch
over boosting?! is it chipped?
Old Dec 5, 2004 | 09:16 AM
ballin's Avatar
ballin
sounds like its hitting the boost limiter.
even more likely this time of year.
Old Dec 5, 2004 | 09:30 AM
L33 BYT's Avatar
L33 BYT
Boost hosing collapsing under boost???
Old Dec 5, 2004 | 02:11 PM
cabrio boy's Avatar
cabrio boy
how could i fix it???
Old Dec 5, 2004 | 02:14 PM
Stoo's Avatar
Stoo
What boost(Psi) are you running?
Sounds like overboost
Old Dec 5, 2004 | 02:21 PM
ballin's Avatar
ballin
is it chipped?
Old Dec 5, 2004 | 02:24 PM
essexrsturbo's Avatar
essexrsturbo
if ya dont tell anyone the answa's to the questions asked how can they tell u how to fix it..
if it aint chipped its hitting overboost, which means its running to much boost for the standard ecu. either get it chipped, or turn the boost down.
if not its sumink else
Old Dec 5, 2004 | 02:27 PM
ballin's Avatar
ballin
pmsl, glad you said it
Old Dec 5, 2004 | 02:29 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Old Dec 5, 2004 | 04:20 PM
cabrio boy's Avatar
cabrio boy
sorry it is chipped pace intercooler dash 31 cossie plugs new ford leads cap and arm its running 10psi it still does it even if i wind the boost in and down to around 6psi it just seems to cut out all the power then back up again real short backfire ???????????????????
