Turbo'ing an EFI XR3i
Old Apr 20, 2009 | 08:01 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Default Turbo'ing an EFI XR3i
Right, I've got an old MK4 XR3i with 102 bhp EFI engine sitting in a shed.
What are the views on just bolting on a T3 from a std RST, plugging in an OFAC ECU and map sensor and running sensible boost (lets say 8 psi max) at a compression ratio of 9.5:1?
Would the ECU be completely off with a wrong compression ratio like that? Would it be worth to keep the increased CR and get aftermarket management or is it better to use an RST block rightaway? I've got all the parts lying here really.
Old Apr 20, 2009 | 08:05 AM
RS 5tu's Avatar
RS 5tu
Use a RST block straight away or do a zvh no point messing about with the 3i bottom end.
Old Apr 20, 2009 | 09:36 AM
orion88's Avatar
orion88
heads good and inlet but as above scrap the bottom end plus you have no oil return for the turbo on that block anyhowsen
Old Apr 20, 2009 | 06:34 PM
user 7082039239
Yeah, fitting oil return to the sump wouldnt be a big deal though. I guess I'll still go down the RST route then...
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
