Washer bottle (front screen) S1
Old Apr 20, 2009 | 06:20 AM
fish6634's Avatar
fish6634
Default Washer bottle (front screen) S1
Am i being really thick here or something? I can't seem to find the washer bottle for my front screen anywhere under the bonnet. The motor to my front jets isn't doing anything when i press the button so i need to investigate to get it working come mot time. Someone point me in the right direction please, i know there is one in the boot, does this supply the front screen too?
Thanks Graeme
PS its an S1
Old Apr 20, 2009 | 07:00 AM
sm's Avatar
sm
the s1 front washer bottle is in between the inner & outer wings, the neck of the bottle should come out of a hole at the front of the passenger side inner wing, to access the bottle jack the car up and u will be able to see the bottle and pump
the boot washer bottle only supplies the rear screen
Old Apr 20, 2009 | 07:57 AM
fish6634's Avatar
fish6634
Mine must have had welding or something in the past as its not there
Old Apr 20, 2009 | 08:52 AM
sm's Avatar
sm
if there is no hole near the front of the passenger inner wing for the bottle neck to come through then your car may of had the inner wing replaced at some point with a xr3i or rs16i inner wing
the xr3i used a rectangular shaped washer bottle which mounted onto the inner wing in the engine bay
the rs16i used a round shaped washer bottle which mounted onto the inner wing in the engine bay
have you checked between the inner and outer wing to make sure there is no bottle there?
try tracing the piping back from the washer jets and see where it goes too
3drRich
Sep 13, 2015 07:32 PM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
