t3 info
Old Apr 19, 2009 | 07:54 PM
mark2's Avatar
mark2
Default t3 info
hi all
done a search for a t3 turbo diagram on here and no luck with the search so can anyone point me in the right direction please
many thanks
mark2
Old Apr 19, 2009 | 07:59 PM
RS 5tu's Avatar
RS 5tu
#1 Journal Bearings
#2 Retaining Rings for Journal Bearings
#3 Piston Ring for Turbine End
#4 Thrust Bearing
#5 Thrust Collar
#6 Seal,
#7 Seal Ring for Bearing Housine
#8 Thrust Spring for Backing Plate
#9 Thrust Spacer
#10 Locknut for Shaft
#11 O-Ring/Gasket for Compressor Housing
#12 Bolts for Compressor End
#13 Clamps for Compressor End
#14 Bolts for Bearing Housing
#15 E-Clip for Swingvalve
#16 Lock Plates for Turbine End
#17 Bolts for Turbine End
#18 Clamps for Turbine End
Old Apr 19, 2009 | 08:01 PM
mark2's Avatar
mark2
hi
f---ing hell
thats fast topman just what i needed
many many thanks
mark2
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
