Fitting trigger sensor assembly to distributor on s2
Old Dec 4, 2004 | 06:44 PM
Peteb's Avatar
Peteb
Default Fitting trigger sensor assembly to distributor on s2
Does anyone know how to fit the trigger sensor assembly on a distributor for the s2?
I have got the distributor off, cleaned etc, but cannot find a way tu pull or remove the main spindle from the distributor body. There does look to be a key way at the base of the distributor that joins the cam shaft, but am reluctant to hammer this out as this may harm it or cause damage. Also I know that the top end of the distributor that breaks the beam, a rotor, is very fragile and I am very relucant to damage this also as it is very thin.
Anyone any ideas or suggestions?
Cheers.
Peteb, Essex
Old Dec 4, 2004 | 06:49 PM
Stoo's Avatar
Stoo
Default Re: Fitting trigger sensor assembly to distributor on s2
Is that the plastic clip thing that sits ontop of the Dizzy?If so,that is what your problem is,its a common fault on RST's.
Cant help you with removing/refitting though.I just bought a new Dizzy
Old Dec 5, 2004 | 06:49 AM
JesseT's Avatar
JesseT
You have to hammer/push the pin out. No way around it really. I have made a nice tool for this. If you come by you may borrow it
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
Aug 21, 2015 06:07 PM
rdvil
Aug 15, 2015 12:11 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
