Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
brakes!!!!!
Old Oct 11, 2003 | 06:07 PM
rsimark's Avatar
rsimark
Default brakes!!!!!
what brake mods have you done if any?? has anyone ever tried fitting a 3i/turbo linkage to improve things / cozzy calipers /rear discs etc?? just being nosey really!!
Old Oct 11, 2003 | 06:36 PM
paul cox's Avatar
paul cox
mines a parachute - that helps me slow done !!!!
quickie or pete will tell you what mods
Old Oct 11, 2003 | 09:09 PM
pete-rsi's Avatar
pete-rsi
Ive just fitted Cossie 2wd front cross drilled/groved disc's with spaced out calipers and S2 rear drums all with braided brake lines and now stops quite well
Old Oct 12, 2003 | 09:06 AM
Quickie's Avatar
Quickie
A series2 set up works well useing calipers, caliper carrier and discs that all bolts staight on The rear end use the S2 stuff as well inc the the back plate drums shoes and cylinders all bolts straight on Get your self some braided brake hoses the goodridge ones fit well and renew all the brake fluid for some good quality stuff like silicon brake fluid then if you spill any on paint work it won't hurt it
Old Oct 13, 2003 | 12:17 PM
paul cox's Avatar
paul cox
now i know what to do to mine
rear disc conversion ???
Old Oct 13, 2003 | 12:55 PM
kvflatman's Avatar
kvflatman
Try thicker soles on your shoes
it works for fred flintstone
Old Oct 13, 2003 | 12:57 PM
paul cox's Avatar
paul cox
i've got a floor pan in my RSI - thank you
will have to go a bit slower then
Old Oct 13, 2003 | 03:27 PM
cosevo's Avatar
cosevo
dont need uprated brakes, and dont bother slowing down for roundabouts and corners, just slide me way round em
Old Oct 13, 2003 | 04:39 PM
rs1600i's Avatar
rs1600i
Default brakes
I'm wanting to put the rear disc convertion as well!! But still not sure! I've bought the spacers for the fitment of cossie discs at the front(heard it improves them!)
Old Oct 13, 2003 | 04:51 PM
Clare's Avatar
Clare
Im running reasonably standard disks and pads, ie nothing special just not your bargain basement type.
When I bought the car it looked like the brake lines had been renewed, they look like copper, is that right?!
Since putting on the new disks and pads she feels much safer to drive, there again, my old brake pads looked about 7 years old, they weren't worn down, just a congealed lump! lol
Old Oct 13, 2003 | 06:03 PM
john_b's Avatar
john_b
I've put 2wd cosworth discs and pads on the front of mine yes it stops a lot better but you car'nt have standered wheels on the car. the problem is the plastic nylon bushes in the bar what go's across the bulkhead if these are worn and with the twist in the bar the brakes are crap. You can go the s1-s2 way with there bars but it will interfere with the induction pipe. i am looking into doing the brakes on mine again by taking all the bars out and putting a rally kit back on,meaning i can put the servo where ever i won't to. more details later on in the year
Old Oct 13, 2003 | 07:50 PM
paul cox's Avatar
paul cox
sounds intresting John - keep us informed matey.
brakes - all i will say is a big difference between my rst and rsi !!!
rst = 300mm disc,ebc greens,standard calipers,braided brake hose's,dot 5.
rsi = cheap discs,cheap pads & 10 y/o fluid
have had my heart in my mouth a few time's - will it stop !!!! (shut eye time)
Old Oct 13, 2003 | 09:12 PM
Quickie's Avatar
Quickie
That poor RSi gets all the good stuff Paula
Old Oct 13, 2003 | 09:14 PM
pete-rsi's Avatar
pete-rsi
You could've fitted all the old S2 stuff on the RSi you knob
Old Oct 13, 2003 | 09:18 PM
Quickie's Avatar
Quickie
That would to easy
Old Oct 13, 2003 | 09:25 PM
pete-rsi's Avatar
pete-rsi
Far to simple
Old Oct 13, 2003 | 09:28 PM
Quickie's Avatar
Quickie
But no helping some
Old Oct 14, 2003 | 08:20 AM
paul cox's Avatar
paul cox
the old RST disc's were wanked big time.
think i'd better do something to the RSI - no good when racing stuff,and they beat me on braking - have to try and out drive um - bloody nova's - corsa's and saxo's
Old Oct 14, 2003 | 05:55 PM
rsimark's Avatar
rsimark
thanks for the reply's i've decided to use s2 brakes with braided hoses as this seems the most simple and effective cure!! still got plenty of nights in the garage refiitting everything after a major body rebuild all good fun tho!!
Old Oct 14, 2003 | 06:19 PM
paul cox's Avatar
paul cox
good luck mark
Old Oct 14, 2003 | 06:38 PM
NUTS RuS's Avatar
NUTS RuS
Bias box with no servo, seperate AP master cylinders plumbed up front to front and back to back, RST calipers with Black Diamond X drilled discs and Mintex 1177/2 pads up front. Home made stainless braided brake lines all round (which also run inside the car - as per our rules). Rear just has Sierra calipers and std motor factors cheapo discs and pads, with a dash adjustable pressure valve to over limit the rears if its too wet.
Pretty standard stuff really.
Hangs you on the belts when the pads are warmed up properly.
Tony
Old Oct 14, 2003 | 07:02 PM
Quickie's Avatar
Quickie
Hmmm rally slag styleeeee
Mark see you got the brakes on Ebay
Old Oct 14, 2003 | 07:46 PM
paul cox's Avatar
paul cox
nice brakes tony
will stop quicker than me RST me thinks
Old Oct 14, 2003 | 08:08 PM
rsimark's Avatar
rsimark
yep well spotted paul thats the back end sorted ,now for the front!!
Old Oct 14, 2003 | 08:42 PM
Quickie's Avatar
Quickie
LOL Ebay stalker
Old Oct 14, 2003 | 08:52 PM
NUTS RuS's Avatar
NUTS RuS
Originally Posted by paul cox
nice brakes tony
Maybe - but it wont go as quick Paul
Old Oct 14, 2003 | 08:53 PM
Quickie's Avatar
Quickie
LOL
Old Oct 15, 2003 | 07:36 AM
paul cox's Avatar
paul cox
you dont reckon !!!!
little challenge then - you will win (me thinks)
Old Oct 17, 2003 | 09:28 PM
Quickie's Avatar
Quickie
Paul give up now i think
Old Oct 17, 2003 | 09:34 PM
NUTS RuS's Avatar
NUTS RuS
bring it on .....
Old Oct 17, 2003 | 09:53 PM
pete-rsi's Avatar
pete-rsi
Will you have to dust the track before you run, Bufty
Old Oct 17, 2003 | 09:58 PM
Quickie's Avatar
Quickie
might get some dirt on the tyres
Old Oct 17, 2003 | 10:05 PM
pete-rsi's Avatar
pete-rsi
NO Paula's excuss will be to much wheelspin due to too much silicone (wet look) spray on the tyres
Old Oct 17, 2003 | 10:06 PM
Quickie's Avatar
Quickie
WET LOOK LMAO bet its wet look hair gel
Old Oct 17, 2003 | 10:08 PM
pete-rsi's Avatar
pete-rsi
Chest hair gel
Old Oct 17, 2003 | 10:11 PM
Quickie's Avatar
Quickie
Chest wig more like LOL
Old Oct 17, 2003 | 10:15 PM
pete-rsi's Avatar
pete-rsi
Mr wiggy in a greased wobbler
Old Oct 17, 2003 | 10:16 PM
Quickie's Avatar
Quickie
LOL
Old Oct 17, 2003 | 10:19 PM
pete-rsi's Avatar
pete-rsi
DANGER - slippery when wet (looked) 178bhp
Old Oct 17, 2003 | 10:21 PM
Quickie's Avatar
Quickie
and thats not just the tyres
