Few gearbox related questions if i may
Old Apr 17, 2009 | 12:03 PM
Jonnie_d's Avatar
Jonnie_d
Default Few gearbox related questions if i may
Hi all,
I have come to the conclusion my gearbox is f****d!
It whines like crazy in most gears and i think it could be part of the cause of my grating through gears and general vibration etc.
Now im unsure if it has LSD or not - iv been told if i spin a wheel then the other should follow suit. Mine does sod all
Is there another way i can find out if it is or not? as i dont want to bother rebuilding it if its not.
Also how hard is it to rebuild for someone who is relativly handy with the spanners? Are any special tools needed etc?
And lastly would a whining noise (that dissapears when clutch pedal is depressed) indicate bearings, cogs, both or something totally different?
Any help greatly appreciated
Old Apr 17, 2009 | 12:08 PM
RS 5tu's Avatar
RS 5tu
if the box is out look through where the drive shafts go, if you see through no problem its got a lsd, if there is a bar there is no lsd.
if its still in the car do a wheel spin 1 line no lsd or a knackerd one 2 lines u have a lsd.
Old Apr 17, 2009 | 12:10 PM
B16CVH's Avatar
B16CVH
Originally Posted by Jonnie_d
Hi all,
If you are spinning the wheel and the other is doing f**k all then you DO have an LSD, it is just worn. If it had a std diff the opposite wheel would spin in the opposite direction. The whining will more than likely be your mainshaft bearing. These are normally the first ti go and are upgraded to a bigger bearing my machining the case to take it, heard of transit & IB5 bearings being used. I would leave it to a pro tbh, they are a real pain in the arse to do, much rather mess with an engine anyday!
Old Apr 17, 2009 | 12:11 PM
RS 5tu's Avatar
RS 5tu
oh and yeh if the wheel turns the same way u have a lsd.
Although the other wheel should turn the other way if there is no lsd iirc
RSandy's Avatar
RSandy
if the whining dissappears entirely when the clutch is depressed, could easily be something as simple as the clutch release bearing
but with the gear crunching and vibrations and the like, it does sound a tad more terminal, when i took mine for its rebuild, i was told it tends to be the bearings collapsing on the end of the main shaft as a usual suspect
easy way to tell if its an LSD item if the box is off the car is to look through the hole where the driveshafts locate into, if u can see straight through, its an LSD item, if theres a bar running across, its not an LSD item
Old Apr 17, 2009 | 06:25 PM
xrmalin's Avatar
xrmalin
If your handy with the spanners you can rebuild it yourself the only specialist bit of kit you need is a gear puller to get the final drive cog off
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
