Anti pump Followers for CVH are they worth it
Old Dec 4, 2004 | 10:02 AM
trev1976's Avatar
trev1976
Default Anti pump Followers for CVH are they worth it
Are they worth changing and whats the advantages?
or are the standard ones just as good
Thanks
Old Dec 4, 2004 | 10:16 AM
Rick's Avatar
Rick
they are if u a revving it past 6k, put that depends on rest of engine.
Old Dec 4, 2004 | 10:30 AM
trev1976's Avatar
trev1976
Hi rick
well ive taken you advice and ive got a MF2 driver 5th injector going on jan 5th and all remapped and fitted by power eneineering also on monday im ordering a pro alloy BIG intercooler so hopefully all that will make a difference
also later on im gonna get steel rods , MLS headgasket , big valve head and while all thats off I was maybe gonna put new cam and followers in (depending on condition) and just wondered what these would be like
Old Dec 4, 2004 | 10:42 AM
trev1976's Avatar
trev1976
heres the Spec if you cant remember
1600cvh
low compression mahle pistons
piper T2 cam
S1 ported inlet manifold
Lightend and balanced bottem end
pace intercooler (normal sized one)
EMC fuel-air mods
mongoose stainless exhaust
hybrid turbo boosting 23psi ( i think this is a stage 3)
-31 actuator
ahmed bajoo mapped engine managment
AP paddle clutch
baileys dump valve
Samco hoses
K+N panel filter
piper vernier pulleys
Old Dec 4, 2004 | 11:29 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
So, what exactly is the difference between an Anti-Pump lifter and a standard one then?? Has anyone ever cut one in half??
Old Dec 4, 2004 | 06:17 PM
trev1976's Avatar
trev1976
yeah id like to know this,because there about Ł100 for a set and wanna know if its worth it
Old Dec 4, 2004 | 08:03 PM
digita1dragon's Avatar
digita1dragon
the difference is a softer spring inside the normal followers have fairly strong springs in, so if you get valve bounce the lifters take up the extra space right away. anti pump ones with softer springs are much slower to react so dont take up the extra space (not in the amount of time you would sensibly be in that situation at least! )
thats how i understand it anyway!
remember kids, always change cams and followers together, if you want the parts to last longer than a few k anyway! ( 4k im my case ) ah well important lesson learned!
Old Dec 4, 2004 | 08:12 PM
Keith B's Avatar
Keith B
I have a brand new set at home unused. When I swapped to a high lift cam and uppedthe rev limit to 7200rpm I swapped to a set of these, didnt have any problems.
Old Dec 4, 2004 | 08:35 PM
lamar69er's Avatar
lamar69er
run anti-pump lifers in mine, never had a problem, Im also using double valve springs in my big valve head!
As stated before there made for high reving egines. Solid lifters is the more extreme way to go!
Would be intesting to chop one up thou! anybody got any old ones, and angle grinder???
Old Dec 4, 2004 | 09:44 PM
Christian and Beccy
#1 in Spelling Club
Its just another one of those things that we are sold not really knowing if they are any different to standard as they look identical externally.
Old Dec 4, 2004 | 09:57 PM
James Raby's Avatar
James Raby
Christian, remember when we replaced mine - could see no difference at ALL
Was better to be safe than sorry at the time though
btw, how the mapping come along?
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
Kam B
Sep 24, 2015 10:40 AM
normink
Wheels and Tyres
Sep 15, 2015 11:25 PM
ajamesc
Sep 8, 2015 06:51 PM
