paddle clutches
Old Apr 16, 2009 | 03:16 PM
orion88's Avatar
orion88
Default paddle clutches
so after much research my conclusion is
that a 22omm ap paddle clutch with a standard brand new clutch cover will handle 200 bhp without slipping and keep the pedle at a sensible biting position?
Old Apr 17, 2009 | 09:25 AM
orion88's Avatar
orion88
no one know this?
Old Apr 17, 2009 | 09:46 AM
RS 5tu's Avatar
RS 5tu
i often wonder why is so hard to find a clutch for an rs turbo to run 200-300bhp
yet there are loads of cars out there running more power on std or uprated ones no problem make me wonder why.
But to answer you question i am not 100% but i think you will be ok.
Old Apr 17, 2009 | 10:40 AM
orion88's Avatar
orion88
ive heard so many people go on about the heavy clutch tho and living in birmingham i just figure fitting the standard cover will give me a nice bite and a clutch that dnt slip upto 200 bhp
only one way to find out i guess
Old Apr 17, 2009 | 10:41 AM
RS 5tu's Avatar
RS 5tu
i am sure if u google it some on will have done it before.
Old Apr 17, 2009 | 12:02 PM
B16CVH's Avatar
B16CVH
A 4-paddle plate with a std clutch cover (or maybe just a slighlty uprated one) will easily cope with 200BHP+. Because you are clamping a smaller area than a std drive plate, you get more clamping force as the pressure plate is concentrating its pressure on a smaller surface area. Years back, i ran a S2 with just a stg1 clutch (wasnt a paddle) and that coped with 220bhp and 225ft/lbs of torque. It is the torque figure that will inevitabley determine whether it will slip, not the BHP.
Old Apr 17, 2009 | 12:34 PM
orion88's Avatar
orion88
and that my friend is the perfect reply
notice ur in the mids too not seen u around mind
Old Apr 18, 2009 | 01:10 AM
Dave S1 Turbo's Avatar
Dave S1 Turbo
i ended up fitting a 220mm flywheel to my S1 with a AP paddle plate and standard cover and works fine and my RS turbo is running 227bhp
Old Apr 18, 2009 | 08:21 AM
Rick's Avatar
Rick
CP2000-8 full AP kit is what you need, none of this stupid mix and match bollocks. Paddle clutch's are for rally and race cars, not road cars. They wear out quickly on a road car, AP do not recommend them.
Old Apr 18, 2009 | 06:53 PM
crazycage's Avatar
crazycage
that is a very good clutch i ran it with 260bhp and 250+ftlbs and it was great .
Old Apr 18, 2009 | 09:22 PM
cozzy940's Avatar
cozzy940
i ran my stg 3 saph with ap clutch motorsportcover much nicer drive mate definitely what id choose
Old Apr 20, 2009 | 10:24 AM
orion88's Avatar
orion88
thanks for your replys all i know where my wages shall be going this month then
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
