Stupid Boost Gauge Question
Old Dec 4, 2004 | 08:35 AM
M7 COS's Avatar
M7 COS
Default Stupid Boost Gauge Question
The S1 I have just bought has this gauge in it:
Could someone please explain to me the purpose of a boost gauge and how you use them when driving, if you know what I mean?
Apologies for my stupidity, but it's best to ask than not really be sure what it's all about.
Thanks
Old Dec 4, 2004 | 09:10 AM
Jim Galbally's Avatar
Jim Galbally
its measuring the pressure of the air as it enters the engine...
a turbocharger compresses the air to allow you to get more air into there...
boost is a measrement of this...
when its reading 0 its at normal atmospheric pressure, which is the same as a non-turbo car will read on full throttle
as the boost starts to come in youll notice the gauge swing round and more and more boost is being made (air is being compressed more) eventually itll stop rising and itll hold a set pressure (when the wastegate starts to open on the turbo hich allows exhaust gasses to bypass the turbocharger t stp it overspeeding)
basiclaly take it for a drive, see what the gauige does...
i the gauge ever starts to do anything different... worry
ps what boost does yours hit on the gauge?
Old Dec 4, 2004 | 09:19 AM
M7 COS's Avatar
M7 COS
Thanks for the reply mate.
I can't rev. it above 3000rpm at the moment so it's barely boosting up at all, when the engines run in and it's set up properly I'll be able to find out.
What should it be?
CheeRS
Old Dec 4, 2004 | 10:27 AM
Jim Galbally
DEPENDS ENTIRELY ON ENGINE SPEC!
capslock
Old Dec 4, 2004 | 10:34 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Theres a boost gague as std on EscCossies too, i thought youd be used to one by now (you driver an esc cos right?).
dont know your spec, but id be guessing on that gague going to 1bar and being safe, but if you dont know the spec AND your still running it in then it obv wont be setup so get it setup before you give it loads or youl just blow the fucker up (and itl be faster once setup).
Old Dec 4, 2004 | 11:24 AM
ballin's Avatar
ballin
dont think he drives an escos steve, just a sig piccy.
is the s1 chipped, surely youd know that when you bought it??
if not, then it should boost to just above 0.5 bar
Old Dec 5, 2004 | 03:23 PM
M7 COS's Avatar
M7 COS
Thanks for the replys guys.
I don't have an Escort Cosworth yet, still looking for the right one.
I used to have a FRST but that didn't have a gauge.
The S1 is chipped, by a certain Mr Bayjoo.
I'll see what it's like when it's run in and set up properly.
CheeRS
Old Dec 5, 2004 | 03:48 PM
The Youth.'s Avatar
The Youth.
The esc cos in his siggy is mine!!! taken at ford fair 2003
Anyway the with boost gauge the more the needle points to the right the more you grip the wheel, thats all you need to know!!!
steve
Old Dec 5, 2004 | 03:54 PM
phil4x4saph's Avatar
phil4x4saph
Turbo boost gauges are there for one reason.
To point at and show your mates!!!
Old Dec 5, 2004 | 08:23 PM
M7 COS's Avatar
M7 COS
steve
Actually one is yours and one is Yum's!
Thanks for the advice.
Needle to right = Hold wheel tight.
CheeRS Steve
Old Dec 5, 2004 | 09:19 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
You gonna get standard grill & relocate the gauge to the a-pillar? Think it will look better..and you don't wanna be looking in the middle of the dash when you are holding on tight!
Old Dec 5, 2004 | 09:25 PM
M7 COS's Avatar
M7 COS
Ooh...that's an idea!!!! Like it!!
Old Dec 5, 2004 | 09:28 PM
mattbibs's Avatar
mattbibs
you should get one in psi and not bar. makes it seem like you are boosting more!!
Old Dec 9, 2004 | 08:12 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Centre grill on e-bay mate: http://cgi.ebay.co.uk/ws/eBayISAPI.d...510014643&rd=1
Just under 3 days left. Buy it...go on. Ya know ya wanna.
Old Dec 9, 2004 | 08:20 PM
M7 COS's Avatar
M7 COS
Cheers mate.
I think I'll be bidding on that.
Can't even see it when I'm driving anyway! How much for a pillar mounted one?
Thanks
Old Dec 9, 2004 | 08:23 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Got mine from Nomad inc gauge at Trax '02. Round about £60 I think..but don't quote me on that. Fit was ok..not perfect, but good enough.
Old Dec 9, 2004 | 08:40 PM
M7 COS's Avatar
M7 COS
Thanks mate
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
