Cold start up - non idling
Old Feb 24, 2004 | 08:29 PM
Default Cold start up - non idling
Hi all,
I have an annoying problem that is most probably easy to fix.......... but I don't know what's buggered to fix it!
When I start the car from cold I have to sit in it (freezing my ass off!) with my foot on the throttle until it's warm enough to tick over itself.......
........... please help o wise ones!
Cheers, Nik
Old Feb 24, 2004 | 09:21 PM
Jo's Avatar
Jo
i would say, have a look at your idle speed control valve, changed mine too recently for not idling like it should
Old Feb 24, 2004 | 09:33 PM
right, I guessed it may have something to do with that.................
next dumbass question!
Where is it & what does it look like & how much does it cost?
Cheers, Nik
Old Feb 24, 2004 | 09:42 PM
THE RADMAN's Avatar
THE RADMAN
on top of the throttle body,round cylinder with greyish plastic top with an electrical plug on top try cleaning it out first,tend to get carboned up
Old Feb 24, 2004 | 09:51 PM
cheers Radman!
Old Feb 24, 2004 | 10:54 PM
Toe Knee's Avatar
Toe Knee
AS said!!, think ur lookin at around Ł80-90 for a new 1 if its needed
Old Feb 25, 2004 | 07:09 AM
Cheers for the help guys!
I've removed it, is there any way to check it's functioning (apart from cleaning & replacing)?
Nik
Old Feb 25, 2004 | 07:25 AM
richm's Avatar
richm
if you take it out and leave it connected, and get someone to turn the ignition on or start the engine (block the hole in the throttle body!) you should see the core moving in the end.
If not, don't just assume it's the valve - may be the wiring or ECU
Old Feb 25, 2004 | 07:55 AM
yeahhhhhhhhhhhhhhhhh, it's working!!
Cheers lads
Old Feb 25, 2004 | 07:56 AM
Jo's Avatar
Jo
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
