ZERO boost
Old Apr 14, 2009 | 08:10 PM
Bomber's Avatar
Bomber
Default ZERO boost
Background: Field Motorsport 2.1ZVH, aftermarket boost control (apexi avc-r), external Tial wastegate with 14psi spring.
Now I had a problem with the engine going spastic when you give it any accelerator or even very light throttle. Field Motorsport said somehow the wires on the ECU end got mixed up and triggered the ALS. All sorted... or so I thought.
Now there is no boost, nothing. Might reach 0psi when rev'd hard otherwise its vacuum all the way.
Changed: MAP, Phase (Zetec CPS due to the coilpack), plugs, leads, injectors and even a new turbo!
Any ideas before it get trailered to Field Motorsport?
Old Apr 14, 2009 | 08:14 PM
Bomber's Avatar
Bomber
Forgot to say i disconnected the apexi - so it would run on the tial at a max of 14psi
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
