rust bubles round sunroof ? easy way to repaire needed
Old Apr 13, 2009 | 04:38 PM
andyjg79's Avatar
andyjg79
Default rust bubles round sunroof ? easy way to repaire needed
hi all after a bit of advice bought my s2 rst ( very cheap ) as a project in need of a bit of tlc under neath is solid engine coming out at the end of the month and also have nsr arch and side sprayed
already put 2 new sills on and smoothed the bonnet getting a replacement bumper in the next couple of days has this one has been cut not a fan really
only part i am having a problem with is the roof as it is bubbling round the front of the sunroof clean drain tubes out wich were full of gunk and rust any surgestions would post pics if i new how
Old Apr 13, 2009 | 04:48 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
how did you clean the drain tubes ????.
dave.
Old Apr 13, 2009 | 04:55 PM
andyjg79's Avatar
andyjg79
didnt do it my self had roof lining removed put air line down drain holes to blow them out look clean from top also having water on passenger floor is this caused buy the drain tube aswell ?
Old Apr 13, 2009 | 05:04 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
i always thought this was one of the hardest areas to stop the rust coming back as ideally you need a new roof skin.
When i had my escort turbo restored i nad another roof skin from a scrap car.
Some one on here called christian i think had big issues too.
Its all about if you want to get rid of it for a long while or not
Old Apr 13, 2009 | 05:43 PM
white2lsr's Avatar
white2lsr
If you take the sunroof out is there enough room to get your hand in with a paint brush to apply rust treatment of would you need to spray it in with a garden sparyer or similar?
Old Apr 13, 2009 | 05:44 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
ive just had my roof resprayed, i had 4 rust patches coming through the size of a 5 pence piece. i had it grinded out treated and fillered looks spot on, cant remember if he said he plated the holes up or not tho. cost me Ł150 which was well worth it i thought.
Old Apr 13, 2009 | 05:47 PM
white2lsr's Avatar
white2lsr
But how long will it last, that is the question!
Old Apr 13, 2009 | 05:57 PM
ROB7656's Avatar
ROB7656
had mine done in an oven by previous owner my uncle body shop tech windscreen out etc and 4yrs later i can see signs of it coming back. truth is the only fix is a new skin
Old Apr 13, 2009 | 06:02 PM
Ebonycossie4x4
Ł150 is an extremely good pricve to rub down plate the holes filler and then paint.
I know a very cheap bodyshop and it would be more like Ł250 for a proper job.
Only semi permanant way is a new skin deffo
Could go carbon fibre roof and get rid of sunroof altogether
im sure people are starting to think about doing it now.
Old Apr 13, 2009 | 06:10 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Cancer of the RST's
Only proper fix is a new roof skin, otherwise you'll be getting it done every 18months or so until it properly rots through.
Old Apr 13, 2009 | 06:15 PM
andyjg79's Avatar
andyjg79
will more than likley try rust treatment on the inside and try plating as i will be having the hole car resprayed next year just need to get the car on the road by the start of next month thanks for all your help and surgestions
looks like a new roof skin next year then thanks again
Old Apr 13, 2009 | 06:18 PM
Micky's Avatar
Micky
If you click on this link it shows very clearly how much rust is under a roof.As said above,this will not be fixed easily or prementally by a Ł200 job.
These picture's are from Chritian's restore/modify thread,a very good read from a bloke who knows what he's talking about
https://passionford.com/forum/showth...t=roof&page=21
Regards,Micky
Old Apr 13, 2009 | 06:25 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As said above, it's the end I'm afraid. I had ONE rust bubble and look what the inside of my roof-skin looked like (in the link above).
A Carbon roof isnt really the answer for an Escort either. How would you do it? Carbon over the existing steel roof? Or cut the roof out altogether? Then where do you join it?
There is no easy answer, thats a fact. Mine will stay with its shitty steel plate over it for now. The roof is knackered, removing the sunroof catridge left the roof in a poor state too.
My RST is in VERY good structural condition apart from this, which is why its worth saving, but many have found their way into the scrap yard for this, even though I realise it looks minor.
Old Apr 13, 2009 | 09:55 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
oh yes,fords rust inside out!so bubbles on the inside means rot on the inside!
Old Apr 13, 2009 | 11:01 PM
RSMK4TURBO's Avatar
RSMK4TURBO
I had mine treated by lead loading the affected area,had it done last june so far no signs of it coming back,it will in time and what a shame you cant get a new roof skin.
Old Apr 14, 2009 | 11:37 AM
andyjg79's Avatar
andyjg79
looks like a big job to come then hope the plates will last for a yr
will have start looking for a skin now
JoeyBoyden
Jan 4, 2024 02:36 PM
3i Jim
Nov 20, 2015 05:12 AM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
