front calipers
does anyone know how i can identify which calipers i have on my car? i took them of a granada, and was told they are the same as 4wd sierra and escort cosworth..i need a caliper repair kit but the microcat is bringing up two different calipers for those cars..unless the seals are the same?? thanks in advance
never took them off a cosworth..think it was a 2.9 ghia??? i have got 2wd sierra cosworth discs and they seem to fit well..also had to space the calipers by 1mm same as the cosworth calipers...whats the difference between the 2 types? is the piston diameter/seal the same? the n/s caliper bracket has 310 on it..cant see a number on the caliper or on the other side
Piston is bigger on the 4wd Cossie one compared to the "normal" calipers.
the discs are def 283mm as i measured them when i got them...do you know if the calipers i hace are fitted to any other cars? it may make it easier to find seals cos im unsure which of the the granada ones im meant to have..cheers
they are not the same as 4x4 cossie ones!
i tried to get a replacement caliper off a granada 24v coswort has the looked similar but were very different when side by side.
Just ask Dojj or Mick. They will confirm what I am saying.
they are fitted tomy erst...i had to drill the hub so that the bolt would fit so am i right in presuming its the m12 fixings i have? think im gonna have to take calipers off and measurethe piston size
the calipers on the 4wd cos and 24v granada are the same
it's the mounting bracket that the caliper bolts onto that is different
these will have either M10 for 90-91 granadas or M12 for the 92-98 granada/scorpio
they also differ on the offset they provide, there is an extra 4mm on the 4wd cos brackets that can be removed if you want to fit them to the XR hubs with 2wd discs
there are more variations with the hubs on the 2.0 dohc 4wd cars but, for this instance, it seems that you've got the later M12 bolts and, by drilling the hubs, you will only be able to use them calipers
on the plus side, you will now be able to bolt on mk3 mondeo calipers and st170 focus 300mm discs
so do you think i have calipers thats the same as 4wd sierra cos? like i said earlier only numbers i can find are 310 on the n/s bracket..just trying to clear this up cos i think im gonna have to replace the seals cos they are sticking..do you know of any other cheap but effective brake upgrade i can do seeing as ive limited my choices by drilling the hub?thanks for the info you gave
ps i have only got standard 15 wheels for series1..got some 3dr cossie wheels aswell that i can fit if this helps fit bigger/better brakes
you've deffo got post 92 granada calipers
or even the mondeo V6 ones for the mk2 if romours are to be believed
measure the inside bit of the piston as this may give you some idea of what they are, but seal kits are cheap as chips, you only have 2, one inner fluid seal and one outer dust seal so as long as you don't use the words "cosworth" you won't get taxed on it as such
i've got loads of them floating about so if you give me the measurements of the inside i can go and check with mine, preferably using vernier calipers rather than an old plastic school ruler though eh
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
