megasquirt no injector pulse
Old Apr 13, 2009 | 06:25 AM
rich123's Avatar
rich123
Default megasquirt no injector pulse
hi all any 1 got any ideas on my problem i have everything working on the megasquirt fuel pump kicking in spark etc etc but i have no injector pulse i get 1 squirt when i turn the key off
any ideas :
Old Apr 13, 2009 | 06:31 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
One of a few things :-
1) Not getting a valid crank signal
2) VR pots not set up correctly in the Ecu
3) Cranking threshold not setup right in calibration
4) Broken ecu/wiring
Old Apr 13, 2009 | 07:00 AM
rich123's Avatar
rich123
does my tfi module count for anything on the pulsing side of things as ive ben trying to find what the wires actualy do but i can only find things for the ranger 2.9 so ive been going of that wiring,the wires i have are
blue/yellow pip out
blue/red spout in
black/green cranking start pwr
black run start pwr
green coil negative
blue/black ground
Old Apr 13, 2009 | 07:05 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Well yes, if the crank sensor is being fed into the TFI module, and then the ECU is relying on the PIP signal to know when to fire the injectors. Have you configured the ECU for TFI inside Megatune?
Old Apr 13, 2009 | 07:07 AM
rich123's Avatar
rich123
yes the ecu is all mapped and set up i got a map from one of the skogenracing lads
Old Apr 13, 2009 | 07:09 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Does it say "cranking" in megatune when you crank the engine?
Old Apr 13, 2009 | 07:11 AM
rich123's Avatar
rich123
ummm not sure were on the megatune does it say that?
Old Apr 13, 2009 | 07:19 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Bottom right
Old Apr 13, 2009 | 07:22 AM
rich123's Avatar
rich123
ok ill go have a look and ill be back
i do reakon i have my tfi wiring wrong but i cant seem to find the right diagrams
Old Apr 13, 2009 | 07:23 AM
rich123's Avatar
rich123
at the bottom right is my flood clear its not that is it
Old Apr 13, 2009 | 07:35 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No, but is flood clear lit up? If so then it means you've got a problem with the TPS, or you haven't calibrated it! Flood clear mode disables the injectors from firing!
Old Apr 13, 2009 | 07:37 AM
rich123's Avatar
rich123
ah i c i think i have wired it up wrong when i crank the engine over the flood light does come on untill i put my foot to the floor then it goes off but comes back on when i lift my foot off the pedal
Old Apr 13, 2009 | 07:39 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yeah sounds like you have your TPS wired up backwards..
Once you've sorted that, go and re-calibrate the TPS in MT and then set your flood clear value to be maybe 20 or so below the max TPS value (at full throttle).. (remember what the high number is when calibrating).
Old Apr 13, 2009 | 07:41 AM
rich123's Avatar
rich123
ok ill go try that now
ill let u know what happens
Old Apr 13, 2009 | 08:04 AM
rich123's Avatar
rich123
we have pulsing now just see if she starts
Old Apr 13, 2009 | 08:29 AM
rich123's Avatar
rich123
nearly started think i need to adjust my timing on the dizzy but my battery dead lol
Old Apr 13, 2009 | 01:38 PM
rich123's Avatar
rich123
yep started at 1.45 does'nt sound bad at all either just need to do a few tweaks with the timing thx for all your help
you going santa pod this weekend if ya are i might see ya down there and ill buy u a beer or 2 lol
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
