ST170 head/Zetec turbo timing belt question
Old Apr 12, 2009 | 08:05 PM
XRT_si's Avatar
XRT_si
Default ST170 head/Zetec turbo timing belt question
So my engine is very nearly finished
Its a silvertop bottem end with a ST170 head, but went to put a timing belt kit on it today and had a few issues with idler set up. Its a silvertop cam belt kit I was using.
Has anyone else used this set up?
Iam sure I could make something work with a bit of time just wondered if there was a easy solution to share that would save me a bit of time!
Old Apr 12, 2009 | 08:12 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
This post has been edited because frankly I can't be arsed.
Old Apr 12, 2009 | 08:26 PM
XRT_si's Avatar
XRT_si
Your shitting me!?
Yes, thanks for the detailed info there but not particularly helpful as its quite evident from the picture its not in the same stage as mentioned previously, therefore I expected you to assume it may have been an old pic
crazycage's Avatar
crazycage
looks to me like you need a blacktop belt on it .
Old Apr 12, 2009 | 08:27 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Originally Posted by XRT_si
Your shitting me!?
Old Apr 12, 2009 | 08:28 PM
TimC's Avatar
TimC
What is the solenoid type thing on the top? Is that for the VCT
Old Apr 12, 2009 | 08:29 PM
XRT_si's Avatar
XRT_si
Yeah I did wonder if it would be easier, but got the silvertop kit sitting here, so was thinking to loose the left hand tensioner, change the right hand idler to a silvertop bigger tensioner and try using the kit I got?
crazycage's Avatar
crazycage
yes
Old Apr 12, 2009 | 08:30 PM
XRT_si's Avatar
XRT_si
Yes mate its for the VVT as I am keeping it
Old Apr 12, 2009 | 08:31 PM
crazycage's Avatar
crazycage
the silver top tensioner is more to the middle from memory ,just use a blacktop belt
Old Apr 12, 2009 | 08:52 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Old Apr 12, 2009 | 09:09 PM
SiZT's Avatar
SiZT
Old Apr 13, 2009 | 12:05 AM
XRT_si's Avatar
XRT_si
Originally Posted by pa_sjo
Assuming doesn't get your engine built.......
How about you tell us what water pump setup you've got? You show us a half-arsed finished engine and ask how to finish it for you?
Crack on you arrogant prick.
There's no need what so ever in the slightest for your derogatory and purposely demeaning posts.
Its perfectly clear from my original post exactly what I meant, as everyone else understood it perfectly.
And if you dont know enough about Zetecs to guess what water pump set up I'll be using on a silvertop engine I suggest you stop trying to make yourself out to be the leading authority on Zetec Turbos. This is not my first Zetec Turbo sweetheart
Go run along now
Old Apr 13, 2009 | 12:10 AM
XRT_si's Avatar
XRT_si
Cheers for that, probably have to, see how I'll get on.
Old Apr 13, 2009 | 01:21 AM
clarke5700's Avatar
clarke5700
Go run along now
lol surley tho it dosent matter what water pump you are useing when it comes down to the timeing belt as in all tho the 2.0 one spins the wrong way its idaler positioning is the same as a 1.8
Old Apr 13, 2009 | 01:32 AM
el_man's Avatar
el_man
si ur a legend lol
Old Apr 13, 2009 | 06:39 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Old Apr 13, 2009 | 05:42 PM
XRT_si's Avatar
XRT_si
I think thats best petal
Old Apr 13, 2009 | 08:37 PM
clarke5700's Avatar
clarke5700
Old Apr 13, 2009 | 11:14 PM
el_man's Avatar
el_man
Old Apr 14, 2009 | 07:12 AM
xrt-mart's Avatar
xrt-mart
I would like to know the answer to this aswell if someone know's
I come across a FRS blacktop head and I have silver top bottom end.
cos elle
Sep 1, 2015 06:48 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
taylora1409
Aug 12, 2015 12:06 PM
