New discs and turbo cooler
Old Apr 11, 2009 | 07:48 PM
RabReith89's Avatar
RabReith89
Default New discs and turbo cooler
Just fitted my new discs and turbo cooler
Old Apr 12, 2009 | 09:44 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Snazzy mate
What does the cooler mount to? might be better slightly left?
Old Apr 12, 2009 | 03:59 PM
RabReith89's Avatar
RabReith89
Cheers buddy
It keeps the water leading to my turbo cool, by the time the water runs from my radiator to the turbo cooler the temp has droped.
Yea i would but the intercooler hose in between the rad and cooler is there
Old Apr 12, 2009 | 04:34 PM
Micky's Avatar
Micky
The front of youre shell is the cleanest,rust free example I've seen in a long time.Have you done a bit of restoring on her???Regards,Micky
Old Apr 13, 2009 | 12:33 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Originally Posted by RabReith89
Cheers buddy
Asked what/where it mounts but good to know what it does
Fair enough though, great mod...
Old Apr 13, 2009 | 12:39 PM
Micky's Avatar
Micky
Originally Posted by Ad4m RST
Snazzy mate
It just mounts to the shell of the car,in approx the same place as the origional std cooler.Regards,Micky
Old Apr 13, 2009 | 04:08 PM
Rick's Avatar
Rick
Mine is tie wrapped in place as i didn't like where it sat!
Old Apr 13, 2009 | 06:18 PM
RabReith89's Avatar
RabReith89
Thanks micky, yea when i was fitting my radiator, intercooler ect done a bit of light sanding then primed ready for my full body spray
I drilled the hole that your spozed to put the bolt thro to hold it bigger, then bolted my own screw and nut then bent the bottom bracket straight, sits spot on
SmudgerByName
52
Jul 28, 2016 06:14 PM
Mark RS
Jan 13, 2016 06:56 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
atm
Sep 1, 2015 04:56 PM
