efi ofac to ofab
hi im running efi setup on my s2 using the 3i loom im now going to change to ofab ive got an ecu and map sensor ect i have to change the wires on the ecu plug, im unsure of what to do with the surpressor do i have to wire this in or is there a plug on the loom already??
also do you have to change the map sensor connector and the air temp sensor plug?
i thought it would work mate but reading the write up on the rsbible it says that its needed to prevent engine melt down, i was just after some info if anybody else has done this thanks mate
liamT74
Sep 23, 2015 10:24 PM
