Gas Flowed Heads
Hi mate contact ian howell at tech@fiestafrenzy.co.uk
for one of his big valve cylinder heads , he one of the best
cheers paul
cheers paul
cheers paul
cheers paul
Hi mate look at the general disscussion , ive managed to talk him in to supplying certain parts mate and one of them is cylinder heads email on that address and he will get back to you, tell paul cheshire sent you
you really need to figure out your end game before you go willy nilly buying bits as you might end up with something over spec'd for it's purpose i'e road car you want lots of response and less lag and around 220 real horses for which standard head would do, as for your question i've got 2 heads in front of me and one cost double the other and the cheaper one is better ported and shaped so it's not just a case of the more you throw at it the better it will be, also the cheaper one is proven to over 350bhp and 160mph+
im making a trackday inspired car mate. I'll not disclose the spec but im going for a reasonable power level with the power more towards the top end. Other than track days the car will be going to shows etc so it will be far far far from a daily driver.
Good advice tho all the same mate
and cheers
Go with ian mate as he will back his work by giving you a no quibble money back guarentee you cant ask for better than that.
Mc5506
Oct 5, 2015 09:57 PM
