how does wastegate springs rates work then?
Old Apr 10, 2009 | 10:14 PM
Stu @ Claims Care Centre's Avatar
Compensation Specialist
Default how does wastegate springs rates work then?
my Tial external wastegate has a red large spring in which is 10psi. iirc this dont mean 10psi of boost it opens? what boost would this spring handle as im going to be running about 2 bar?
Old Apr 10, 2009 | 10:17 PM
mechanic28's Avatar
mechanic28
pretty sure it does mean that the spring can only take 10psi of pressure before it gets compressed!like any set up you just beeld off the excess boost until u get to ya set boost then allow the actuator to see 10psi
Old Apr 10, 2009 | 10:21 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The harder the spring, the less duty you run on the boost control valve.
If you ask me, you want to keep the deficit between the two as low as possible. My Tial 'gate is sprung to 1.5 bar, however that does mean it's the least boost you can run.
Old Apr 10, 2009 | 10:25 PM
ok so i can still run my 2 bar but the least i can run is 15psi?
Old Apr 10, 2009 | 10:28 PM
Christian and Beccy
#1 in Spelling Club
Well, I can't comment on Cossie gay boost control, but take my setup for example. My 1.5 bar spring results in a minimum pressure of around 1.4-1.45 bar of boost. I can then use a valve to allow more boost on top of that. So, valve off is 1.4 bar, valve at around 40% duty makes around 1.8 bar.
If my wastegate were sprung to 1.0 bar, it might take 80% duty on the valve to achieve 1.8 bar and the more you ask the valve to do, the more it can become unstable.
Thats my take on it.
Old Apr 10, 2009 | 10:31 PM
so you must have a large and a small blue spring in yours. i need to get a stronger spring really as ill never want to run anything under 20psi. it was a pain trying to get the red spring in and bolting it up at same time let alone a stronger spring
Old Apr 10, 2009 | 10:37 PM
mechanic28's Avatar
mechanic28
your min boost would be 10psi i would say as that your spring rating
Old Apr 10, 2009 | 10:41 PM
im running air injectors but would prefer a stronger spring in there so i dont have to use a lot of duty to get to 2 bar
Old Apr 10, 2009 | 10:54 PM
mechanic28's Avatar
mechanic28
ah ok i am running twin airs as well but running a 14.5 spring -34 are u on oe ecu?
Old Apr 11, 2009 | 05:58 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The more duty you run, the finer the resolution, the better the control... as long as it's mapped properly..
Old Apr 11, 2009 | 07:05 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
the spring rates you require are more to do with exhaust back pressure when running high boost
Old Apr 11, 2009 | 07:07 AM
im running Emerald on a MSD Single Air injector setup
Old Apr 15, 2009 | 04:55 PM
Shonky's Avatar
Shonky
V6 Ka of Love
If I want to run the minimum of 6psi and maximum of 14psi with an external wastegate do I use a 6psi spring and use a manual bleed valve stop the wastegate opening to allow 14psi?
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
saph in dorset
Aug 14, 2015 10:10 AM
Aug 14, 2015 07:29 AM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
