Zetec cambelt snapped!!!!!!
Old Apr 10, 2009 | 08:49 PM
mercury grey minter's Avatar
mercury grey minter
Default Zetec cambelt snapped!!!!!!
As above ,was driving to wales for the easter break today and cambelt snapped on the motorway.Now back home making a list of what i need.
I want the easiest option so don,t want to muck about changing valves.
1.6 ZETEC SE .52 PLATE FOCUS.
Please add to this list of the things i might need,any help would be appreciated.
COMPLETE HEAD
BELT TENSIONER
BELT
HEAD GASKET
HEAD BOLTS
Old Apr 10, 2009 | 08:52 PM
OldDan's Avatar
OldDan
Crank pulley bolt.
OldDan's Avatar
OldDan
Camshaft seals.
Old Apr 10, 2009 | 09:07 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Complete head gasket set,
New exhaust manifold and downpipe nuts (not crucial but I would ),
Crankshaft pulley bolt. (crucial as the pulley is free floating until the bolt is tightened),
Old Apr 11, 2009 | 12:10 AM
neilm's Avatar
neilm
Just get a new engine from a breakers and swap the lot in one hit and while the replacement engine it out on the floor do the cam belt on it.
Old Apr 11, 2009 | 12:42 AM
yellowsierra's Avatar
yellowsierra
Bugger !!
Beat me to it, Exactly what i'd do
Just had my belt done, not cheap but cheaper than an Engine on an Escort/Focus
Old Apr 11, 2009 | 12:56 AM
rst in breaking's Avatar
rst in breaking
has it bent rods etc?
Old Apr 11, 2009 | 07:49 AM
mercury grey minter
Wouldn,t of thought so ,but this is the first time a belts snapped on me so don,t know what to expect.RAC man says pistons are never damaged with a belt snap,just the valves.
If the rods are f*cked then deffo fit a complete engine.
Off now to buy a Ł400 escort as a runaround for the mrs till it,s done.
Old Apr 11, 2009 | 07:57 AM
GUZZLER's Avatar
GUZZLER
some people used to fit a new crank pulley as well, sometimes even with a new bolt they pulley can slip..... depends how much he likes the car as to how much he wants to spend on it.
Old Apr 11, 2009 | 08:33 AM
OldDan's Avatar
OldDan
Pulley will be fine to use again!
Definitely need a new pulley bolt..
Probably marked the pistons but could of fucked them!
Old Apr 11, 2009 | 08:50 AM
B16 Will's Avatar
B16 Will
its all about the 5 pot
Gutted, whats the mileage on it, 100k belt intervals arnt they?
Old Apr 11, 2009 | 11:48 AM
mercury grey minter
Was told the belts are good for 100,000 or 10 years.Mine had done 72,000 and is only 7 years old
RAC man says they should be changed at 60,000 ,but what do they know.lol
Old Apr 11, 2009 | 02:10 PM
nicksaph's Avatar
nicksaph
i have seen a lot cam belt failures on engines befor the manufactures interval. which when all said and done is only a guide when to change the belt under normal conditions.
userly it is a tensioner or water pump that fails and causes the problem
and also if the car has been not looked after very well or abused these are all factors that affect belt life
i change the belt on my car every 2 years approx 20000miles
not all brakedown men are mindless dim wits, some actully know what they are on about
cheeRS nick
Old Apr 11, 2009 | 02:35 PM
Fiddy's Avatar
Fiddy
My mothers snapped on her focus the other week, a year after having a new belt and kit fitted by rapid fit. the bill came Ł850 to fix it, but she didnt have to pay, they took responsibility, although they did try to get her to pay for the parts and wave the labour charge. ford say that black top zetec belts should last 100k or 10 years, silver top 50k miles or 5 years, but as they guy at ford told me, thats not set in stone, its just a guideline
Old Apr 11, 2009 | 07:18 PM
mercury grey minter
Little update.Stripped it down today as far as i could .The belt hasn,t snapped,a quater of the teeth on the belt are missing.What could cause this as i don,t want to change the head and belt and it happen again.Can,t remove the head as my tools are at work.
Didn,t know you had to remove the cams to get to the head bolts.
Old Apr 11, 2009 | 08:50 PM
OldDan's Avatar
OldDan
Tensioner could of failed and skipped a few teeth?
Old Apr 11, 2009 | 09:19 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
On the 1.7 Zetec SE engine they reduced the cambelt interval from 100k /10 years to 80k/5 years due to a lot of failures.
Seen a lot of 1.6 zetec SE's going wrong recently!!!
tons of the engines available cheap so may well be less hassle to engine swap.
Old Apr 11, 2009 | 11:59 PM
mercury grey minter
Am tempted to just engine swap now i,ve stripped it all down.With a secondhand head ,belts,gaskets e.c.t ,i,m looking at about Ł200.Can get an engine 50,000 miles for Ł300.Will take the head off and see if pistons are maked,if so deffo engine swap.
I thought my rs was unreliable.lol
Old Apr 12, 2009 | 12:03 AM
Psycho Warren
Carbon Crazy
Zetec SE's are usually pretty reliable. certainly more so than most abused CVH turbos!!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Chas
Oct 5, 2015 07:13 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
