Turbo Removal
Old Apr 8, 2009 | 04:57 PM
duffers's Avatar
duffers
Lame
Default Turbo Removal
Hi all,
Just wandering whats the easiest way to remove both the Turbo & Manifold from my s2 as I have a new one to put in, does it need taking apart bit by bit or will it just slide out in one piece with the manifold still strapped to the turbo?
I'm rather lazy but not too lazy to give it a go myself!
Any help/ advice appreciated.
Col
Old Apr 8, 2009 | 05:00 PM
RobL's Avatar
RobL
i took my rad and intercooler off and pulled it out the front
was easy enough dunno if theres an easier way
Old Apr 8, 2009 | 05:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Undo manfold from head and drop out the bottom! Just need to remove starter and downpipe
Have pulled it out the top but that cost me some paint
Old Apr 8, 2009 | 05:44 PM
ram's Avatar
ram
Has a large member
as above, can come out the top but you will scratch lol. i found that out too.
Old Apr 8, 2009 | 06:02 PM
sm's Avatar
sm
put some cardboard between the rad/intercooler and the turbo before u remove it that way you wont damage any of the fins
addiction's Avatar
addiction
Take the turbo off the manifold first (it's only 4 nuts) and it will come up through quite easily if your carefull. Then take the manifold off.
Old Apr 8, 2009 | 08:35 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just take it all out of the top, i can do it in my mk2 fiesta without damaging anything and my rst cab too.
Old Apr 8, 2009 | 08:42 PM
RabReith89's Avatar
RabReith89
As RobL said, worked well for me
Old Apr 8, 2009 | 08:49 PM
duffers's Avatar
duffers
Lame
Wow, loads of replies, thanks chaps!
I'm gonna crack on with this 2moro, not sure which route I'll take yet but I'll let you know if a turbo hits me on the head while I'm under it!!
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
kevin36
Aug 14, 2015 08:36 AM
