fuel leak from metering unit Pic included
hi my s2 rs turbo has a fuel leak it seems to be leaking from the highlighted bit in red, im pretty sure its the red pipe, any one have a spare one, preferbly with the bolt on the end of it they want to sell me or know where i can get one. Im pretty desperate for the part as im using my car as a daily drive at the moment,
thanks
thanks
its definatly the red pipe as i could see the fuel leaking out of it also the pipe was not securley connected to the banjo, i seperated it and then could not re attatch it to the banjo lol well not as secure as the one in the pic above.
Thanks
Thanks
bit of an update i changed the pipe for a braided one and thought its sorted but obviously not
there is a small leak the bolt which connects the injector line to the metering unit that seems to leak, is there sealing washer under the bolt that i can just replace?
Yep all of the fuel lines on the metering unit should have a copper washer either side IIRC, you can still buy all of the banjo's and washers new at Ford, you can still even get the MU gasket too, i think the only part i couldn't get hold of for refurbing my metering unit was a hanger and the bolts that bolt the unit together.
