Mondeo 18's
Old Mar 30, 2009 | 02:37 PM
Sp3no's Avatar
Sp3no
Default Mondeo 18's
What would it take to fit 18" Mondeo ST alloys to a ST170?? are they a different stud pattern?
Old Mar 30, 2009 | 02:41 PM
andy130's Avatar
andy130
mk3 mondeos are 5stud focus are 4stud
Old Mar 30, 2009 | 04:11 PM
thebigmacmoomin's Avatar
thebigmacmoomin
A lot of work. Mondeo ST alloys is 7.5x18 but is 5 stud.
Old Mar 30, 2009 | 07:16 PM
stevierob's Avatar
stevierob
Hi 05 onwards are 5 stud i'm sure??
steve
Old Mar 30, 2009 | 07:19 PM
RichieST's Avatar
RichieST
steve
But you can't get an st170 on an 05 onwards.....
Its only the new shape focus that is 5 stud.
Old Mar 30, 2009 | 10:01 PM
Sp3no's Avatar
Sp3no
Thought as much, right here is one then, mondeo's have the same caliper and disks as a ST170? is it possible to swap to 5 stud hubs? If its do able im wanting to do this swap
Old Mar 30, 2009 | 10:32 PM
G420 DEL's Avatar
G420 DEL
would some hubcentric adapters not be easier.. if theres none of the shelf you can have some made up.
Old Mar 31, 2009 | 06:20 AM
RichieST's Avatar
RichieST
The only real way to tell would be to compare an st170 front hub to a mondeo hub, compare sizes, number of driveshaft splines etc.
I imagine that the fronts might be do-able, but the rears could be more difficult!
If you do go for it, let me know how u get on
Old Apr 1, 2009 | 12:10 PM
Sp3no's Avatar
Sp3no
I shall investigate, i love the improved factory look and i thought a set of almost identical St170 wheels but in 18" would look ace, if it proved too expensive Oz Super T's might be the only way
Old Apr 3, 2009 | 12:18 PM
Sp3no's Avatar
Sp3no
I have now seen 5 stud conversions done on a focus via re drilling the hub, from what i can gather the mondeo and focus hub is very similar, need to be the two together, it seems the fronts might be easy as pie to do as it will be a parts swapping excercise but the rears might be difficult
Old Apr 3, 2009 | 01:16 PM
RichieST's Avatar
RichieST
See if you can find and compary wheel bearing dimensions. Have alook about online, most sites that sells them tells you the dimensions. As long as the inner diameter and the width is the same then its looking like its possible.
Just have to compare driveshafts!
Could be worth perhaps getting a mondeo hub and a focus hub from a breakers perhaps?
Old Apr 6, 2009 | 12:28 PM
Sp3no's Avatar
Sp3no
One thing i have spotted is that the wheel bearings have a different part number on the focus and mondeo, the ST220 even has a unique drive shaft and bearing to most other Mondeo's too. Still investigating!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
