Cosworth Fuel pipes
Old Mar 28, 2009 | 08:04 PM
Barry R's Avatar
Barry R
Default Cosworth Fuel pipes
How do i disconnect the fuel return of my fuel rail on a 3 dr cosworth
Need to take the engine out in the morning
Old Mar 28, 2009 | 10:03 PM
JonathanJ's Avatar
JonathanJ
The fuel return is the easy one under the fuel pressure regulator , think its the fuel feed you will be struggling with , how I did it when I did not have a tool was find a piece of plasic that is just thinner than the gap , looking in the garage remembered what I used , it was the top of a touch up pencil from ford , cut the tube so it is about 1" long then cut it along its length on 1 side so you can slip it over the pipe so that you can the push it forward to stretch the spring to allow the two components to come apart , hope this helps , if you need a better idea you can pm me for my tel no
Also why do you need a scrap loom ?
Old Mar 28, 2009 | 10:10 PM
Barry R's Avatar
Barry R
Pmed
Old Mar 28, 2009 | 10:24 PM
JonathanJ's Avatar
JonathanJ
pmed back
s1cab
Jul 26, 2018 06:11 PM
155lee
14
Aug 22, 2015 12:15 PM
Aug 14, 2015 07:29 AM
muffster
Aug 12, 2015 08:14 PM
Old ford
Jul 31, 2015 06:50 AM
