ecu feed probs!!!
Old Dec 1, 2004 | 09:41 PM
cossiescott's Avatar
cossiescott
Default ecu feed probs!!!
ive got no feed to the main ecu on my s2 rs turbo!!
does anyone know wot colour the wire is and where it comes form???
Old Dec 4, 2004 | 10:13 AM
Rick's Avatar
Rick
Which ECU? Fuel or Ignition? It ultimately comes from the pink relay under the dash.
Old Dec 4, 2004 | 11:33 AM
DazC's Avatar
DazC
Rick, the pink relay relies on ignition pulses to run the fuel pump so the car has to at least have a working ignition system before that relay will switch on. That means the ignition ECU has to be switched on first to be able to switch the coil to get the pulses for the tachometric relay....
I can repair them pink relays as well...
Daft question..have you checked the heated seat fuse? Don't ask, just do it!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
