300bhp Cosworth advice
Old Mar 27, 2009 | 06:41 PM
meridian's Avatar
meridian
Default 300bhp Cosworth advice
Hi,
Have got a very clean 2wd Sapphire Cosworth currently running an old Brooklyn Motorsport Phase 0 260bhp conversion.
Want to go a little further and just want a nice, untemperamental, nice sounding, quick road car circa 300bhp but not looking to spend a fortune. Car is a weekend toy. Engine is fit and healthy and has Mongoose exhaust, GP A Cone filter, Bailey dump valve and Samco boost hoses. Also has Koni adjustable suspension and Tarox discs.
Looking to go Bayoo stage 3 chip, 803 greens, 3 bar Map, -31 Actuator with boost of 20-21psi and would have it set up properly. Do not want the expense of new ECU, T34 or bigger intercooler (yet). Realistically, is 300bhp possible with the above spec. utilising standard T3 and intercooler. Also, is engine breather kit needed at these outputs.
What are your thoughts ? Any other or better suggestions how to achieve reliable 300bhp ish with standard ECU, T3 and 2wd intercooler ?
Old Mar 27, 2009 | 06:45 PM
BigErn's Avatar
BigErn
why does it have to stay on standard cooler? A cheap 4x4 one is a good upgrade over standard 2wd.
Have you thought about a Norris Gunship?
Old Mar 27, 2009 | 10:17 PM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by meridian
Hi,
yes 300hp is easily obtainable with the above spec; however as big urn states you will need a 4x4 intercooler - the rest is fine as it is. the 4x4 cooler is slight deeper than a 2wd cooler, but is alot better
i would always recommend getting a aftermarket engine breather on a standard engine as quite frankly the standard item is crap
300hp on a t3 will be a very punchy road car and is a good set up
i had a MSD (motorsport developments) chip in my 2wd and it was brilliant, wouldnt use anything else
if you havent already you need to rewire your fuel pump for a direct feed from the battery, this is a MUST for all cossies
its easy to do, i have a wiring diagram if needed
Matt
Old Mar 28, 2009 | 01:03 PM
meridian's Avatar
meridian
Thanks for the replies. Good point about the 4x4 intercooler and will look to source one. So many owners must upgrade to alloy units that there must be loads about in people's garages. If anyone's got one please let me know and I'll happily buy it.
Have moved on with this now. Have ordered Stage 3 kit from Woodford Garage with Bayoo chip and also have bought Bailey breather and swirl pot. Going to get it set up at M.A. Developments who I spoke to this morning. Should be a fun road car !
Matt. Would be interested in the wiring diagram. Is it emailable ? If so, email is djsar@ukonline.co.uk
Do let me know if you've got a 4x4 intercooler. Thanks. Damon 07770 784970
Old Mar 28, 2009 | 05:47 PM
meridian's Avatar
meridian
Got a 4x4 intercooler from Markyd3, 15 miles down the road ! Bit of luck, with a nice stainless cover too. Cheers Mark, nice meeting you.
Old Mar 28, 2009 | 05:54 PM
LHD220Turbo
i'm sure Mark will insist on having it rewired anyway - but here you go
Old Mar 28, 2009 | 07:30 PM
meridian's Avatar
meridian
Cheers Matt
Old May 25, 2009 | 09:08 PM
sgt_pepper's Avatar
sgt_pepper
Hi, just wondering what price this setup will roughly come in at?
Old May 25, 2009 | 09:33 PM
Staffi's Avatar
Staffi
Is rewiring the pump a MUST on a standard cossie too then Matt??
Old May 25, 2009 | 09:39 PM
LHD220Turbo
yes Pete bud, in my opinion anyhow. i've seen 9v at the pump before on idle, imagine what that would drop to while on boost!
the problem is wiring deteriates over time, which means you lose current etc. considering some cossies are 20+ years old now alot of the looms have seen much better days.
i'd always say to everyone to rewire their fuel pump for a direct feed from the battery
Old May 25, 2009 | 09:52 PM
Staffi's Avatar
Staffi
Agree 100% Matt, prevention BETTER than cure AND alot cheaper...
Old May 25, 2009 | 09:59 PM
LHD220Turbo
yeah, i'm on the same wave length as you there!
these old Fords need all the help they can get
Russ Hill
Aug 31, 2015 06:44 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
