How common are Dash Illumination problems?
Just got my dream car and have been told that the two problems mine has are quite common and worst of all you can't even get replacement parts now!
1) Centre guages have 'discoloured' at night and cannot be repaired (new part £300 odd quid!)
2) Airflow and speed dial lights have just gone out although the temp still works. Part un-available but can be repaired by taking a feed from the temp light.
Any other Escos owners had the same?
I had the dials go on and off - changed the voltage converter or whatever that is called and everything works fine. The other fings you have problems with- try brakers on the forums - somebody rolled Escos some time ago so there are those parts from it probably.
Originally Posted by THE RADMAN
yeah,i fitted a set of those on mine,no more blotches!!
The Enigma
Sep 12, 2015 10:12 PM
