Im putting another engine in my escort, and this was bolted to back of the meterin unit, the 4th injector pipe has bin curved up and the other end goes on the meterin unit. wasnt sure if anyone is usin one, or no's what it is/does.
Any idea?
its a fuel flow sender/sensor for the fuel comp and is worth fuk all as no one uses the fuel comp these days,the beepin when ur low on fuel gets annoyin
