How do I set the ignition timing on my RST?
Old Mar 24, 2009 | 08:30 AM
adam.d's Avatar
adam.d
Default How do I set the ignition timing on my RST?
How do I set the position of the dizzy on my RST? think I need a timing light and I've heard that it needs to be set at 12deg BDC is this correct?
Old Mar 24, 2009 | 09:01 AM
Oranoco's Avatar
Oranoco
Get it running and nurse it to a specialist who can then set the car up properly. Most places can make the cars run most can't make them run right
Old Mar 24, 2009 | 03:48 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
as above get it running best u can then get it set up.
Old Mar 24, 2009 | 04:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes that is correct if you are running standard boost, make sure you remove the MAP sensor hose form the ECU when you do it though!
Then go and get it set up
Billy_RS
16
Oct 11, 2025 09:41 PM
FlashRS
Aug 30, 2015 08:07 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Zoggon
Aug 10, 2015 10:39 AM
dlwarrior
Aug 5, 2015 10:19 AM
