xr2i zetec to rs1800 spec
Old Mar 22, 2009 | 07:56 PM
Fiesta_ie's Avatar
Fiesta_ie
Sandpaperman in acction
Default xr2i zetec to rs1800 spec
hey guys what's the differences between the 105hp and 130hp?
de head its the same? throttle? cams? Ecu?
Old Apr 1, 2009 | 05:25 PM
wildheart's Avatar
wildheart
Cams
Throttle body
ECU
Air flow meter.
Old Apr 12, 2009 | 12:10 PM
Fiesta_ie's Avatar
Fiesta_ie
the head is the same? my throttle body has 55mm but has the sticker of the 105
Old Apr 12, 2009 | 12:27 PM
fiend's Avatar
fiend
Inlet
Cams
Throttle body
MAF Sensor
ECU
Inlet manifold is bigger on an RS1800, they have HO stamped underneath too so you can tell its an RS1800 one. I would assume the inlet ports are bigger too.
They also have oil jets in the bottom end.
The early ones also have a different downpipe.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
