s2 the deck protrusion??
thanks for the info so far.
it is standard.
but done a search on this and found this about cvh heads
from karl norris
many thanks
wayne
it is standard.but done a search on this and found this about cvh heads
You CANNOT use the lean burn 1.6cvh head on a std RS turbo bottom end. This is because the std RS turbo has a 2mm piston protrusion at TDC above the deck height. The head gasket is only 1.5mm thick, and hence if you fit the lean burn head to a std RS turbo bottom end, the pistons will make heavy contact with the combustion chamber "beak" resulting in horrendous noise and bent con-rods!!
A second issue is the high compression ratio this results in, but that is insignificant in comparison to the 1st problem!!!!!
many thanks
wayne
Disabled Account
Jun 14, 2005 06:17 PM
