got the saff out for a clean today!
i wish i could change them mate, some plank super glued them on before i had it, they pull the paint off if you try to remove them, i have tried all sorts
Originally Posted by Random forum
Super glue is a real hard one to get off your autos finish. cars today are painted with a base coat/clear coat paint system. the crazy glue bonds to the clear coat quite well.They make remover for crazy glue, but if you rub to hard you can remove the clear coat which will result in a flat looking color spot which will have no gloss at all.So be careful. If it does come off, you can go to a auto supply store and get some rubbing compound that is clear coat safe and that will bring the gloss back to the aera.
The cheapest and nastiest superglue set from the pound shop comes with a tube of de-bonder - try that. You may need to have the area gently sanded with a very fine grit wet & dry (used wet) then repolished/laquered.
Very very nice lovw the colour and love the wheels.I used to have mud flaps on my car when i first got it but i took them off.I like mine without the flaps on.
Thanks for the comments guys, i am yet to try super glue remover, i am always worried about what effects it will have on the paint, but i guess its worth a go!
Really dont want to pull paint off her though!
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Cos500
Sep 16, 2015 09:50 PM
Adam Graham
Sep 6, 2015 06:04 AM
just cant be asked
