1.3/1.4/1.6 cvh sump same as rst?
Simple question again, can i use s2 rst normal cvh sump? I have one spare engine, but it has rusty sump. Breakers has normal cvh sumps all around.
The oil return pipe off the turbo goes into the side of the block not the sump unless a zvh conversion (i think not 100% sure), Not sure bout the other cvh sumps they will go on as there the same shape just not sure about the baffles inside of them as stated before
The CVH engine has an oil return pipe INSIDE the sump which runs vertically down from the block which keeps it away from the crank.
mk3ste
Oct 17, 2021 10:09 AM
