Any SKY Engineers in tonight ???
I,ve got a telly set up in the conservatory for the kids. We have Sky plus but theirs has stopped working. It says input 1 is not locked. I,ve checked the connectors at the back of the box and from the dish for input 1 and they look fine. Is there anything else i should look at ?
Cheers Gaz
Cheers Gaz
Sometimes turning the power off at the wall for 20seconds and then turning it back on solves some issues, so might be worth a shot as above.
You will have to give it a few mins to sort itself out when you turn it back on
Tried switching off at the box and the wall but its still the same.I forgot to mention that our other sky plus box is unaffected and working fine .
