Tools explained
Old Mar 17, 2009 | 09:30 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Default Tools explained
Tools Explained...A Valuable Guide
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh dash...."
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense Welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, Vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Old Mar 17, 2009 | 09:36 AM
Brookesy's Avatar
Brookesy
Sounds about right
You missed off angle grinder though
Old Mar 17, 2009 | 09:37 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
How true!!!
Old Mar 17, 2009 | 09:38 AM
Chip's Avatar
Chip
ANGLE GRINDER
A tool used for removing bone from fingers
Old Mar 17, 2009 | 09:42 AM
nilrem's Avatar
nilrem
STOP!... Carry on
ANGLE GRINDER
or
A tool used to cut & grind a minimum area of 100mm around the rounded bolt - rounded from the failed attempts from pliers and vise-grips - you were wanting to grind off resulting in some major bodywork refurb.
Old Mar 17, 2009 | 09:44 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
All pretty much spot on.
Old Mar 17, 2009 | 11:01 AM
Barry R's Avatar
Barry R
Class.
They didnt teach that in college, Now its much clearer
Old Mar 17, 2009 | 11:50 AM
Rob Virgo's Avatar
Rob Virgo
best list ive seen.....................EVER
have done them all
Old Mar 17, 2009 | 12:01 PM
daviddunlop83's Avatar
daviddunlop83
Originally Posted by Lee_R21Turbo
How true!!!
Second that. Been there a couple of times.
Old Mar 17, 2009 | 12:07 PM
Patto's Avatar
Patto
funny as fook lol
Old Mar 17, 2009 | 02:20 PM
Red16's Avatar
Red16
very true to life list
Old Mar 17, 2009 | 02:24 PM
fordsportjay's Avatar
fordsportjay
brilliant!
can relate to every one
JK12
33
Apr 26, 2021 12:09 PM
grishenko45
Sep 9, 2015 12:58 PM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
