i/s/c/v
Old Nov 30, 2004 | 05:33 PM
THE RADMAN's Avatar
THE RADMAN
Default i/s/c/v
just pulled up at a junction tonight and the idle speed control valve went beserk,it was idling at 3000rpm then down /up and all over the place,then cut out, restarted it and it seems fine,ill have a look at the valve at the weekend but any other ideas?
Old Nov 30, 2004 | 07:39 PM
Glenn5's Avatar
Glenn5
same happened 2 mine a while bk mine blew all the inlet gaskets 2 pieces
Old Dec 1, 2004 | 07:05 PM
Monte 76's Avatar
Monte 76
Just had mine cleaned as I had the same problem!
seems fine now.
