Rear hub nut size
Mar 16, 2009 | 08:20 PM
Rear hub nut size
what is the size of the nut on the rear hub, i need to adjust my wheel bearings.
thanks
Mar 16, 2009 | 09:56 PM
use some grips or an adjustable spanner, the nut shouldn't be very tight
Mar 16, 2009 | 10:06 PM
Sorry to hijack but could this cause the wheel to feel loose when jacked up?
Just jacked back end of mine up the other day and noticed you could rock it up and down and side to side?
Mar 16, 2009 | 10:08 PM
yeah either the bearing is worn excessively or incorrectly adjusted
Mar 16, 2009 | 10:09 PM
Ah right, thought it might be but you could still spin the wheel freely so wasn't sure! I'll give that a tighten up when i next go work on it!
Cheers for help!
Mar 16, 2009 | 10:12 PM
with the handbrake off you should nip the nut for the wheel bearing up gently, then slowly slacken it off till you can just slide the washer behind the nut when you push against it with a screwdriver hope this helps
Also put a new split pin in afterwards
Mar 16, 2009 | 10:15 PM
Yep that's great mate thanks!
Mar 16, 2009 | 10:37 PM
from memory im pretty sure u tighten the nut to 18lb/ft, and then slacken off by half a turn, and thats the job jobbed
atm
Sep 1, 2015 04:56 PM
Ridgey
Aug 30, 2015 08:37 AM
rst-s1
Aug 23, 2015 07:56 AM
track.focus'd
Aug 12, 2015 05:53 PM
2000 ,
2005 ,
bearing ,
escort ,
focus ,
ford ,
hub ,
hubnut ,
nut ,
nuts ,
rear ,
sierra ,
size ,
tool ,
wheel ,
xr4x4
