How reliable can an RST be?????
Old Mar 16, 2009 | 12:23 PM
adam.d's Avatar
adam.d
Default How reliable can an RST be?????
As some know, I've had endless problems with my escort. I'm now rebuilding another engine for it. I've stripped the bottom end and checked / had everything checked and refitted with new shells, oil pump and gaskets. I've bought a ported + polished head with a piper cam, again I've stripped and cleaned it and rebuilt it with new seals and gaskets. I've used a good H/G and new head bolts and new timing belt. Hopefully I've done everything I can to make this as reliable as possible as I can't afford to spend anything else on it! The turbo has only done a hand full of miles since I bought it. This is it's last chance to be a reliable car as I've already spent a fortune on it and I paid too much in the 1st place for it It only gets used on a weekend as it's a second car.
Old Mar 16, 2009 | 12:40 PM
RS 5tu's Avatar
RS 5tu
"How reliable can an RST be?????"
Very if you look after it.
Old Mar 16, 2009 | 12:51 PM
orion88's Avatar
orion88
well i had a cab that was put together by a chimp and it broke down a hell of a lot yet ive just redone mine and other than teething troubles its sound
Old Mar 16, 2009 | 12:54 PM
MattyRST's Avatar
MattyRST
Mine has be fine (touch wood) !!! damn ive cursed it now lol !!!
Old Mar 16, 2009 | 01:21 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Set up correctly they can be more reliable than new cars. Less electronical crap in there that could go wrong.
The engine is pretty much bullet-proof in standard trim, with regular servicing and the injection system in good nick.
Old Mar 16, 2009 | 01:30 PM
S2PAUL88's Avatar
S2PAUL88
i have put 3000 miles on mine since i bought it a couple of months ago its running around 190bhp and hasnt even coughed or splattered yet!!!
Old Mar 16, 2009 | 02:18 PM
orion88's Avatar
orion88
think its all about the set up tbh cos mine and 2 of my mates are never on trhe rd at the same time lol
Old Mar 16, 2009 | 04:04 PM
danny_boy699's Avatar
danny_boy699
chatter 4 life
my mates runs all the time no problem, just the rest of the car is falling apart
Old Mar 16, 2009 | 05:07 PM
addiction's Avatar
addiction
If it's put together properly and looked after properly it will be ultra reliable!!!!!!
Old Mar 16, 2009 | 10:31 PM
DazC's Avatar
DazC
I did 19k miles in my S1 with no serious issues. Just the odd fuel pump failure which I rectified by wiring in another relay.
Old Mar 17, 2009 | 05:32 PM
marshyrst's Avatar
marshyrst
not had any real problems with any of my rs turbos there good if ya dont cain them
Old Mar 17, 2009 | 05:55 PM
boost monster's Avatar
boost monster
Mine has done 145k miles, 100k by me at 15 psi boost. I`ve had 2 gearbox rebuilds and i freshened up the engine at 143k it only needed rings and shells everything was still within Ford tolerance. Iam still on the original turbo! I changed the oil and filter every 3k and had a RR set up every year, its never let me down yet
Old Mar 17, 2009 | 06:12 PM
Brian's Avatar
Brian
We used our old Series 2 every day of the year for 2 1/2 years and it never let us down once
Brian
Old Mar 17, 2009 | 06:30 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
judging by the thread the other day as long as you dont race anything modern like a clio itll be fine.
if you do though itll break big time.
Old Mar 19, 2009 | 08:17 PM
ROB7656's Avatar
ROB7656
they can be reliable. mines done nearly 130k engine has never been apart origional turbo runs sweet. tuner reckons she could see another 50k.
Old Mar 19, 2009 | 08:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Old Mar 19, 2009 | 09:00 PM
adam.d's Avatar
adam.d
Well mine isn't very reliable after fitting my rebuilt bottom end and supposedly good S/H head it's rattling it's tits off if it's not fixed tomorro I think I'll have to fire it!!!!!!!!!!!
Old Mar 19, 2009 | 09:28 PM
RabReith89's Avatar
RabReith89
At the end of the day guys its a 19 or 21 year old car and if its not been looked after service not to frashed ect since day one its gonna be a pain in the arse unless u refresh every thing, Or you could be unlucky like this chap and have a friday car.
Long story short mine is not bad so far cause i give it nothing but the best she is vert high maintence lol
Old Mar 19, 2009 | 10:02 PM
kevb1979's Avatar
kevb1979
my girlfriends s2 is on 140k on original engine and turbo only started to get a slight problem with it now (read other post) but otherwise neva been a problem as long as ya look after them and regular oil changes thay last
Old Mar 19, 2009 | 10:19 PM
Chris69's Avatar
Chris69
there great if looked after and if corners aren't cut- ford did a pretty good job with the rs turbo we just all messed it up cus of bleed valves and the like lol
Old Mar 19, 2009 | 10:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The more money you spend the more reliable they get........... but mostly they start very unreliable
Old Mar 20, 2009 | 06:24 AM
ROB7656's Avatar
ROB7656
all down to regular services good oil etc i swear by mobil1 thats all mines had for the last 15 years
Old Mar 20, 2009 | 07:10 AM
siemens's Avatar
siemens
When you see under the bonnet of some!!
Absolute shite -wires all over the place/spliced here and there,hoses taped up to make joints some with paper masking tape!
And generally fucked about with.
Think! --was it like that in the begining of its life??
no wonder problems occur is it?
Old Mar 20, 2009 | 08:12 AM
G420 DEL's Avatar
G420 DEL
ive had mine 5 year ish, never had an issue with it. if i have its becuase of me (no oil gettin 3rd insted of 5th bla bla bla)
Old Mar 20, 2009 | 09:47 AM
Oranoco's Avatar
Oranoco
I got my Escort RS Turbo 15 years ago this April (18th iirc) and it was always used as a daily runner up until I moved in with my missus about 4 years ago. In all th eyears it was a daily runner it always got me to and from work and rarely put a foot wrong. TBH the only reason it isn't still a daily car is as I needed something more suitable for my work, something I could park without panicing about and I just didn't want to spoil it using it daily
Old Mar 20, 2009 | 05:22 PM
rsmark86's Avatar
rsmark86
alright mate i would change the cam belt kit water pump plugs and leads ect as then they are loverly and you get the piece of mind that its all good ...good luck with the build
Old Mar 23, 2009 | 12:28 AM
tejy's Avatar
tejy
yep yep so true just treat your escort service it regulary etc and it will be fine. my mates are scared to go in mine because the old engine kept cutting out and breaking down before it died..now i got a new engine test drove it to essex and back and was running super smooth....i love it!!! im going to do an oil and filter change, and give it a new air filter this easter......dont have a girl to treat out so thought might aswell treat my car (which happens to me my baby anyway) ..
Old Mar 23, 2009 | 05:30 AM
Antti O's Avatar
Antti O
RS Turbo would be proper car for everyday use for its reliability if properly looked after.
Old Mar 23, 2009 | 07:35 AM
Stu @ M Developments's Avatar
PassionFords Creator
This is relevant to this topic so may be of interest to people:
http://www.motorsport-developments.c...AF261_tech.pdf
Old Mar 24, 2009 | 07:13 PM
barnard's Avatar
barnard
mine has let me down twice in 4 years with a crunch in the gearbox and a starter motor apart from that nothing else works but it gos lol
Old Mar 24, 2009 | 09:05 PM
rstel1's Avatar
rstel1
as said above they are reliable if looked after
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
