front disks warpped
i got standard brake setup on my rs, and the front diss ae warpped,, what would you recomend me having, i would like to keep the calipers,, but if it makes more sence changing then i will..
Not too much really 4x4 escort cozzie calipers think I snipered them on ebay for about Ł40
the 2wd cozzie discs were Ł55 from the local motor factors, Ł25 for some brake pads from same factors.
if you look at the guide near the top section of the rs turbo section there's a detailed how to guide.
I've got another set of calipers but 1 of them has a snapped bleed nipple which I couldn't remove even after heating with oxy acet/ drilling and using snap on easy outs.
When they've bedded in they should be good, esp as the cab still had the 239mm discs on it, 283mm looks much better under the alloys too
brake engineering, i've fitted loads of these over my 13 years in motor trade
plus brake enginnering are making them for a cozzie and there fitted on a lighter car so in theory will not be under as much pressure
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
