General Ignorance
Old Mar 14, 2009 | 04:48 PM
BR1GG5Y's Avatar
BR1GG5Y
Default General Ignorance
Hello, Been reading for a while, I think this is my firs tpost. I now have to deal with some surface rust, bubbling paint. So I need to clarify some things;
Rust treatment, there is rust remover, rust converter plus other stuff, any advice on what is best and the differences.
What is the difference in Etch Primer and High Build Primer?
When and were do you use underseal, hammerite or stone chip? What the advantages of one against the other?
Thanks
Old Mar 14, 2009 | 05:43 PM
RSandy's Avatar
RSandy
rust treatments and the like are purely to prolong the situation, not fix it, the only sure fire way to remove rust is to grind it back, and cut out the bad material, and weld in fresh metal
etch primer is used on bare metal and welds, it essentially 'bites' in to the metal, protecting it from rusting away. high build is used after the etch process, it is much thicker, and builds a base for the paint coat to adhere to
the undersealing process seams to be a lot of personal preference, depending upon what kind of finish u want under there. anything waxoyl based will remain tacky and wnt dry completely, makes it better for rust protection, but can look shite and cant be overcoated. things like underbody schutz will dry and form an almost rubber feeling layer, but cant be overcoated so remains black. stonechip tends to be used in situations where the owner will then overcoat this with paint to match the bodywork. hammerite can be used directly on the bare surface, or also over the stonechip sealant below as a coloured overcoat
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
