wheel offset and size
I'd run at least ET35, infact I run ET30 on mine and I wouldn't dream of running 215 section tyres unless your car was REALLY fierce. 205 at the most (thats what I run on mine).
Anyone who has been to a thrash that I have attended will tell you that I am 100% top speed focussed and don't bother laying down sprint times until I reach my top speed goal as I would rather not break the gearbox first.
we've managed to run r888's with well over 300 ponies and gave a few evo's the slip of the line and as yet the box not had any issues and going to push it over next few weeks with 400 on tap with gas
strange that maybe you run crazy amounts of boost(over 25psi) and as it all comes in while in 3rd it's doing it in where as we run sub 20 psi so spike is less severe maybe luck, hope you get your top speed your after soon then maybe we might be able to go head to head on strip
Power is power at the end of the day. The BC 'box is rated to around 150lb/ft AFAIK and whether you have the power by way of high comp/low boost or low comp/high boost, if it has the power, it will break the gearbox.
I upgraded to IB5's several years ago and have spanked alot of those too.
The amount of boost isn't really relevant, the torque is. Mine is around 300lb/ft and is actually quite flat. It couldn't be a more gearbox friendly torque curve really.
i find that just giving it death from 1st off the line right through the gears there ok but if you plant it at 40mph in 3rd it breaks.
what is your top speed goal? i thought it was 170 but you did that last year.
Adam Graham
Sep 6, 2015 06:04 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
